HotRodder Offline
#1 Posted : Saturday, 14 February 2009 10:01:43 AM(UTC)
HotRodder
Just wondering if anyone can help me with this problem, when the engine is idling it runs fine even when I rev the engine at the carby its very smooth but as soon as I put it in reverse and drive off or put it in drive and go forward it has a terrible miss in the engine. Now Ive replaced the filter, distrubitor cap and rotor I've even swaped over a different coil and it still has the miss.
I first noticed it 20 klms out of Mackay in the pouring rain,I sprayed the CRC and by luck it came good a bit down the road then when I arrived home after 1000klms it started getting worst even to the stage when it wouldnt even fire. I've blown out the carby and replaced the parts as before but the problem exists. The engine is a blue 253 with all the pollution gear, can anyone suggest a sollution to get her running again. Thanks Mary
Edited by user Saturday, 14 February 2009 7:04:51 PM(UTC)  | Reason: Not specified
#2 Posted : Saturday, 14 February 2009 8:14:31 PM(UTC)
The blue v8 had electronic ignition from factory , check to see if it has spark when its not firing ,no spark could mean the module has packed up on an elec dizzy.
check the vaccum lines for cond , leaks can cause rough running as can carby gaskets.
basketcasebear Offline
#3 Posted : Saturday, 14 February 2009 10:01:37 PM(UTC)
basketcasebear
hey hotrodder,
this may not be your cause, but i was getting an intermitant miss,, which was quite marked, i even posted about it,
i found it,,
it was sparking across from the alternator to the metal bracket near the alt,,
found it eventually, but be
DOH!!!
HotRodder Offline
#4 Posted : Sunday, 15 February 2009 12:38:59 AM(UTC)
HotRodder
Hi Guys, Im now thinking its not the carby as Ive replaced the gaskets and installed a full kit I even replaced the manifold gasket, I had another look at it last night and she runs so sweet when idling or when the engines reeved but like I said as soon a
#5 Posted : Sunday, 15 February 2009 6:32:44 AM(UTC)
basketcasebear
hey rodder,
my girlfriend had that prob in a camira,
it was the in line fuel filter, soon as fuel pressure got higher, it blocked,
hope it helps
bcb
said the weathercock to the wind,> "how tedious and monotonous you are, can you not bl
DOH!!!
#6 Posted : Sunday, 15 February 2009 7:41:27 AM(UTC)
Hey Hotrodder , lift the bonnet slightly in a dark place whilst the engine is running to see if any sparks are escaping there proper route,i did this one night by mistake actually and there were sparks everywhere(easy fix/elimination process).Might not be
HQforme Offline
#7 Posted : Sunday, 15 February 2009 11:11:22 AM(UTC)
HQforme
If it only happens under load then it sounds like a fuel pressure problem maybe? Im chasing something quite similar in my mates classic BMW. Im working on it tomorrow, let you know if i find anything that could be relevant.
"Silly modern cars"
HotRodder Offline
#8 Posted : Sunday, 15 February 2009 12:11:48 PM(UTC)
HotRodder
Yes fuel pressure thats my next thing on my list, I have a brand new fuel pump kit for it. Ive replaced the fuel filter as soon as the problem started and just came back from checking for sparks no sparks. Well like you said its a matter of elimination.
HotRodder Offline
#9 Posted : Monday, 16 February 2009 6:35:00 PM(UTC)
HotRodder
Well guys Ive replaced the fuel pump kit and guess what the problems solved. It now idles well and reves at the carby and drives like a new car.
HotRodder Offline
#10 Posted : Tuesday, 24 February 2009 10:34:28 AM(UTC)
HotRodder
Update - The HQ only ran for 20klms and then she started the putt,putt,putt again so it surely has to be a fuel problem.
Im wondering if it might be possible to have water in the fuel as the problem first started about 50klms after refilling the car in h
peterwmh Offline
#11 Posted : Tuesday, 24 February 2009 6:59:27 PM(UTC)
peterwmh
Have you tried a bottle of metho in the tank, it binds to the water and will help clear the tank of it. Cheers
202 and three on the tree, cant get more Aussie than that!!
#12 Posted : Tuesday, 24 February 2009 7:20:08 PM(UTC)
Browno Offline
#13 Posted : Wednesday, 25 February 2009 4:04:04 AM(UTC)
Browno
should put that trick in the , tricks found when doing up a car thread
Drive It Like You Stole It......Drive it like you own it
Blue ballz Offline
#14 Posted : Friday, 6 March 2009 6:36:06 AM(UTC)
Blue ballz
Does ethanol affect a car much?
#15 Posted : Friday, 6 March 2009 6:53:07 AM(UTC)
Guest (6)
