HotRodder Offline
#1 Posted : Sunday, 15 February 2009 7:10:25 AM(UTC)
HotRodder
Hi Guys, Just a couple of questions are the HQ to HZ v8 one tonner differential housings the same and will the disc brake set up bolt onto a drum brake v8 differential housing. Cheerio Mary
adam PERTH Offline
#2 Posted : Sunday, 15 February 2009 9:06:05 AM(UTC)
adam PERTH
the yoke cup size is the next one up on the 1 ton. 1.1/8 ? compared to ute / van
Be careful to check that, as the diff may be in a 1 tonner, hpwever it may have come out of a ute / van originally.
the disks will go on., but if your pulling them off a
HotRodder Offline
#3 Posted : Sunday, 15 February 2009 12:21:49 PM(UTC)
HotRodder
I thought the one tonner and the vans are all the same, the v8 differential I have is from a HQ panelvan. No problems with the cable, they can be made to suit any application.
#4 Posted : Sunday, 15 February 2009 9:44:14 PM(UTC)
HQ-WB ute/van/tonner housings are the same except HZ and WB have the swaybar brackets on them. As Adam says the tonners have the larger yoke, and they also have larger axles. The disc brake setup will bolt on but you need the disc brake axles as well. On
HotRodder Offline
#5 Posted : Monday, 16 February 2009 1:22:59 AM(UTC)
HotRodder
Hi Guys, Does anyone know so I can check to see if I even have a V8 differential first what are the measurement of the V8 axles for the one tonner anmd the panelvan and while Im at it how about the measurements of the six cylinder axles.Cheers Mary
#6 Posted : Monday, 16 February 2009 1:46:38 AM(UTC)
6cyl are banjos 10 spline or 23 spline axles except in WB where they are disguised banjos (small salisbury with 23 spline axles). If its a 10-bolt its a V8 diff except for 1-tonners where they are all 10-bolts. 1-tonner has thicker axles that are machined
HotRodder Offline
#7 Posted : Monday, 16 February 2009 1:54:05 AM(UTC)
HotRodder
What does this 10 bolt mean are there 10 bolts on the housing or internals somewhere.
#8 Posted : Monday, 16 February 2009 3:08:02 AM(UTC)
10-bolts to hold the crownwheel to the hemisphere, but also 10-bolts on the housing rear cover (by co-incidence).
