hq71 Offline
#1 Posted : Monday, 16 February 2009 5:55:21 AM(UTC)
hq71
just wanting to know why an oil filter would have all the guts of it caved in. thanks
vintageholden Offline
#2 Posted : Monday, 16 February 2009 6:52:38 AM(UTC)
vintageholden
when a center tube or element has collapsed, it is usually the result of a sticking or otherwise malfunctioning bypass valve. The oil pump pressure regulating valve may also stick in the closed position, which results in increased pressure and oil flow th
hq71 Offline
#3 Posted : Monday, 16 February 2009 7:15:07 AM(UTC)
hq71
thanks heaps ill drop the new oil and see if its crushed this filter and go from there.
gmholdman Offline
#4 Posted : Monday, 16 February 2009 7:45:43 AM(UTC)
gmholdman
When in the engine reco business we had a few collapsed filters take place on 253/308 and all were fitted with new after market oil pumps,changed to original pumps(new and second hand)and no more problems. Are you using a new pump??? AL.
crowe Offline
#5 Posted : Wednesday, 18 February 2009 9:13:56 AM(UTC)
crowe
Was it the large or smaller reto filter? As the large filter would have more paper and larger surface area to pass more oil with less restriction? Is that right lads?
