klompy Offline
#1 Posted : Monday, 16 February 2009 10:44:08 PM(UTC)
klompy
Hi there how easy is it to fit a HZ combo switch into a HQ.Is the wiring colour for colour or are there hassles.Thanks.
#2 Posted : Monday, 9 March 2009 3:41:49 PM(UTC)
99% sure its colour for colour. Whenever Ive played with Holden harnesss the colour for application is the same whatever the model. Seems alot of work and buggering a harness or 2 just to get wipers closer to your fingers. How much does it rain in Rotorua
klompy Offline
#3 Posted : Monday, 9 March 2009 7:03:47 PM(UTC)
klompy
When I finaly got an original switch it was easy but must of started out with a aftermarket replacement which is binned know.Rotorua is nice and green at the moment and a great place to be.Thanks for the reply.
#4 Posted : Monday, 9 March 2009 8:17:50 PM(UTC)
You have to replace the column section with the combo switch and ignition key in it. Not very hard but takes a bit of time. Blinker mech is a straight unlug and plug back in but you need to do some wiring for the combo switch. Best bet is to cut the socke
