klompy Offline
#1 Posted : Monday, 16 February 2009 10:44:08 PM(UTC)
klompy
Hi there how easy is it to fit a HZ combo switch into a HQ.Is the wiring colour for colour or are there hassles.Thanks.
#2 Posted : Monday, 9 March 2009 3:41:49 PM(UTC)
99% sure its colour for colour. Whenever Ive played with Holden harnesss the colour for application is the same whatever the model. Seems alot of work and buggering a harness or 2 just to get wipers closer to your fingers. How much does it rain in Rotorua
klompy Offline
#3 Posted : Monday, 9 March 2009 7:03:47 PM(UTC)
klompy
When I finaly got an original switch it was easy but must of started out with a aftermarket replacement which is binned know.Rotorua is nice and green at the moment and a great place to be.Thanks for the reply.
#4 Posted : Monday, 9 March 2009 8:17:50 PM(UTC)
You have to replace the column section with the combo switch and ignition key in it. Not very hard but takes a bit of time. Blinker mech is a straight unlug and plug back in but you need to do some wiring for the combo switch. Best bet is to cut the socke
This page was generated in 0.110 seconds.
