wannabe51 Offline
#1 Posted : Thursday, 19 February 2009 9:55:06 PM(UTC)
wannabe51
Hello all,
can anybody advise me why I cannot bolt on a Trimatic V* bell housing to a 6 cyl. Trimatic. My sons 253 ute has a burned out transmission and I want to put in GWO trans from a six.
look forward to your advice.
Dave
#2 Posted : Thursday, 19 February 2009 11:29:53 PM(UTC)
Pump.
Number of clutches.
Speedo drive gear.
Selector location.
Easier and cheaper to find a good 253 or 308 box.
adam PERTH Offline
#3 Posted : Friday, 20 February 2009 2:56:05 AM(UTC)
adam PERTH
have tried this a few times, not much success.
Was told once by an auto transmission guy that bellhousing and box they are a "machined pair"
and i guess they will warp slightly together over 20 years as well..
WANTED:
QR 662xxx
1984 WB oyster c
Edited by user Friday, 20 February 2009 2:59:36 AM(UTC)  | Reason: Not specified
#4 Posted : Friday, 20 February 2009 4:05:13 AM(UTC)
The two main obstacles when fitting a 6-cyl Tri-Matic auto to a V8 engine, would the bell-housing & the input shaft (different spline & length).
As adam PERTH says, both faces must be flat & not warped otherwise you will have other dramas. As Byron men
peter_flane Offline
#5 Posted : Friday, 20 February 2009 4:08:13 AM(UTC)
peter_flane
I guessed Good Working Order? Am I right?
#6 Posted : Friday, 20 February 2009 6:06:43 AM(UTC)
AHH acronyms !!
peter_flane Offline
#7 Posted : Friday, 20 February 2009 6:09:30 AM(UTC)
peter_flane
Originally posted by Dr Terry
AHH acronyms !!
#8 Posted : Friday, 20 February 2009 6:16:13 AM(UTC)
Touche
wannabe51 Offline
#9 Posted : Friday, 20 February 2009 8:05:51 PM(UTC)
wannabe51
Thank you all for your advice. the answer is clear, I will repair the original box.
thanks all.
Guest (5)
