vanman Offline
#1 Posted : Saturday, 21 February 2009 8:24:53 AM(UTC)
vanman
Hi all I posted this question a while ago and I am still a little unsure of the best way to fill the windows on my XX7 Sandman, it has 2 side windows, one half size on each side..
I have 5 options
1/. Weld a plate in, to plug the hole..
2/. Glue a plate in, and fill the hole...
3/. Unpick the entire side panel and replace the whole side...
4/. Replace the entire roof and both sides....
5/. Dont touch it....:(
I have 2 complete windowless vans at my disposal and have just removed the sides from another so the complete panels are not a problem...
I was thinking of trying to weld the windows with the mig, (keeping heat to a minimum) and then if it warps too much i will try the sides or complete roof and sides...
Any help greatly appriciated...
Vanman
Gary Thorpe Offline
#2 Posted : Saturday, 21 February 2009 8:27:41 AM(UTC)
Gary Thorpe
where are you located ?
I know a guy in Pakenham Vic. who could do the full side swap.
I saw the results after he replaced the side panels of an EH van... cool !
Gary T
www.hdhrholden.com
www.oldsmobilesdownunder.com
Gary T
Jvanner Offline
#3 Posted : Saturday, 21 February 2009 11:24:22 AM(UTC)
Jvanner
i welded windows in for a made. its a really slow job. but you need to make sure both windows line up. some vans the windows dont line up. the shell in that spot has warped alittle. i ended up cutting out the body between the 2 windows and used a 2mm flat
#4 Posted : Saturday, 21 February 2009 9:03:45 PM(UTC)
Jvanner is right , If I was goin to do it thats how I would do it,glue it on first then tack weld around at different spots(avoiding too much heat in one spot).ETC.Then use a product called ..Metalfill its hard to work with but REALLY GOOD . It sets like
hzsandman Offline
#5 Posted : Sunday, 22 February 2009 12:57:55 AM(UTC)
hzsandman
I am also getting this done to my van and have had heard all the options you mentioned. Everyone seems to have a different and "best" way of going about it.
I am going for the weld in 2 separate plates on each side. (one for each window). Spot weldin
hainzy Offline
#6 Posted : Sunday, 22 February 2009 4:09:44 AM(UTC)
hainzy
There was a really good post on here about this a year or two ago. I think it was by rogoth?? It had heaps of pictures and was quite informative. I think he used panel glue? ive tried to search for it but cant find it. Perhaps its been archived?
vanman Offline
#7 Posted : Sunday, 22 February 2009 5:28:13 AM(UTC)
vanman
Thanks for the info All its a great help.
I found this post... http://www.fastlane.com.au/foru...CHIVE=true&TOPIC_ID=2611
Is the Henrob torch a realistic option...
I dont want to deck out the rear of the van, i want it to lo
hainzy Offline
#8 Posted : Sunday, 22 February 2009 5:38:34 AM(UTC)
hainzy
hey yeah thats the post I think but it had quite a few photos though. not sure where theyve gone.
#9 Posted : Sunday, 22 February 2009 6:29:54 AM(UTC)
B&H Wreckers in Clayton ( higgs52 is his name on ebay ) has NOS side Panels (the whole windowless bit )you are all looking for . I am not sure he has both sides , but i know they are genuine GMH New Old Stock . Only problem is to fit them as holden did th
Ado Offline
#10 Posted : Monday, 23 February 2009 8:56:00 PM(UTC)
Ado
Think the problem with side panels on a van are similar to welding panels into bonnets. A guy was doing up a HT van and wanted to put the monaro scoops into his standard bonnet. The old timer doing the job said to his mind the best way was to put a step i
hzsandman Offline
#11 Posted : Tuesday, 10 March 2009 1:57:20 AM(UTC)
hzsandman
does anybody know when the Holden vans changed the support strut setup in their vans? I have an HZ which has a straight roof rail but I noticed when I got some support struts to weld back into my van that earlier vans had a downward groove at the top of
hzsandman Offline
#12 Posted : Tuesday, 10 March 2009 1:58:34 AM(UTC)
hzsandman
Sorry, HQ Style:
Rhys Offline
#13 Posted : Tuesday, 10 March 2009 5:12:40 AM(UTC)
Rhys
hzsandman,
The HZ van that you have pictured came out of the factory with full length headlining. Any van with factory full length headlining had the extra strips of sheet metal spot welded to the rails on each side, so the lacing and bows had something
hzsandman Offline
#14 Posted : Tuesday, 10 March 2009 5:11:01 PM(UTC)
hzsandman
Thanks Rhys, that explains it then. Not a version thing.
hzsandman Offline
#15 Posted : Monday, 6 April 2009 7:51:02 PM(UTC)
hzsandman
Finished now.....
[I
hainzy Offline
#16 Posted : Tuesday, 7 April 2009 1:17:34 AM(UTC)
hainzy
Very nice work mate. Well done. Just need to get the stripes back on now! Great colour too!
#17 Posted : Tuesday, 7 April 2009 3:47:47 AM(UTC)
what a fantastic job, nice pics
if it wasnt for the last minute id get nothing done
#18 Posted : Tuesday, 7 April 2009 3:59:01 AM(UTC)
heres a pic of the rear of my hq panelvan, btw its ex ambo
it currantly undergoing a full resto atm
http://gallery.oldholden...air+folded+down.jpg.html
hzsandman Offline
#19 Posted : Tuesday, 7 April 2009 4:19:34 AM(UTC)
hzsandman
I can not claim the credit. Done by a professional.
#20 Posted : Tuesday, 7 April 2009 4:43:38 AM(UTC)
well done,
see, it proves that anything can be done when you put your mind to it, especially when it comes to this sort of work.
all the previous posts in this thread telling you to go to B&H Wreckers for NOS quarters and all that rubbish, and cut her
Edited by user Tuesday, 7 April 2009 4:53:33 AM(UTC)  | Reason: Not specified
This page was generated in 0.196 seconds.
