78XC Offline
#1 Posted : Sunday, 22 February 2009 1:26:31 AM(UTC)
78XC
I've heard the term before in reguards to engine blocks but have no Ideal what they fill with resin and it's annoying me so any info will help my blood pressure hehe thanks
Browno Offline
#2 Posted : Sunday, 22 February 2009 2:47:13 AM(UTC)
Browno
and grout filled??
Drive It Like You Stole It......Drive it like you own it
russxr67 Offline
#3 Posted : Sunday, 22 February 2009 5:28:30 AM(UTC)
russxr67
When you hear the term "resin " or "grout" filled ,the term is indicating that the block has been filled with either of the two substances in the water jacket in order to give the bores a more rigid footing.
It is primarily done on cleveland blocks bec
#4 Posted : Sunday, 22 February 2009 10:49:01 AM(UTC)
with very high compression the bore walls flex and you lose performance. the resin is pumped into the water jacket and reinforces it. seeing as there is no water in there the motor can only be run for short periods, as in drag cars.
78XC Offline
#5 Posted : Sunday, 22 February 2009 9:41:44 PM(UTC)
78XC
thanks guy's thats good I never thought they would fill the water jackets so def not good for street applications. thanks again.
russxr67 Offline
#6 Posted : Thursday, 26 February 2009 7:58:25 AM(UTC)
russxr67
If you keep the fill to the level that i explained then running on the street is not an issue. You still have some 3 inches of uncovered bore left.
If it is a concern then you can use less fill. It is a very common practice on cleveland blocks whether t
russxr67 Offline
#7 Posted : Thursday, 26 February 2009 8:03:19 AM(UTC)
russxr67
Sorry,I should have added that i filled mine so that the if you fill it whilst the engine is being built on a stand have the deck in a horizontal position and pour the fill in till it reaches the bottom of the water pump outlets in the front of the block.
78XC Offline
#8 Posted : Friday, 27 February 2009 8:06:26 AM(UTC)
78XC
very interesting thanks for that is there a special kind of grout of filler you use, I've got my motor out I might look into doing it myself.
russxr67 Offline
#9 Posted : Sunday, 1 March 2009 5:14:20 AM(UTC)
russxr67
Hard block or Moroso engine filler.
78XC Offline
#10 Posted : Monday, 2 March 2009 9:19:53 AM(UTC)
78XC
thanks for that I appreciate it.
