darryl Offline
#1 Posted : Sunday, 22 February 2009 8:51:46 PM(UTC)
darryl
Hi, has any one put a Trimatic in a hr and do you have to alter the floor in any way? Cheers.
#2 Posted : Monday, 23 February 2009 3:33:00 AM(UTC)
A Tri-Matic is virtually a bolt-in fit to an HD/HR if you use the steering column, crossmember & tailshaft from a Powerglide model. Then use an LC/LJ 6-cyl speedo cable, they have the correct fittings & are longer than an HG cable. The only fiddle is fabr
This page was generated in 0.015 seconds.
