Blue ballz Offline
#1 Posted : Friday, 6 March 2009 6:22:26 AM(UTC)
Blue ballz
Howdy,
I have recently acquired a vs calais and taking previous advice are going to swap the engine loom and all the wiring looms to get some creature comforts into my manual ute. However I would like to try and keep my ute as a munual. Have checked previous forums and have found much that has helped. So I have a couple of questions.
1. Can you swap an auto to a manual?
2. Do you need to do anything to the loom to accept a manual?
#2 Posted : Friday, 6 March 2009 6:49:17 AM(UTC)
VS manual and auto use different ECU and Memcal (at least in the earlier models), plus there is a fair bit of difference between VS through to VSIII. Im no expert on them but it sounds like a lot of work to me. Im pretty sure the auto and manual harnesses
#3 Posted : Friday, 6 March 2009 8:14:36 AM(UTC)
If your ute is also a VS, then the VS calais body harness swap into the ute is the best bet - entire body & dash harness (play with the wires to mate up the rear harness).
Retain your engine harness, and its plug-n-play into the Calais one.
Only 1 p
