308hjute Offline
#1 Posted : Sunday, 8 March 2009 7:30:27 AM(UTC)
308hjute
Guys,
What is the definitive method for iding Aussie four speeds? ie. 2 grooves on the input shaft = M21? Correct or not?
Kev
#2 Posted : Sunday, 8 March 2009 7:44:11 AM(UTC)
i have also heard that the m21 has 2 grooves on the input shat, however im no expert on g/boxes
i would also like to know the answer is
if it wasnt for the last minute id get nothing done
JBM Offline
#3 Posted : Sunday, 8 March 2009 9:00:18 AM(UTC)
JBM
The best way is to open the side cover and get the cluster gear Part No.
All Aussie 3 and 4 speeds have the same casing and the only difference between an M20 and a normal M21 is the first gear ratio. Same with the M22 and XU1 M20.
Input shafts are in
ITCH Offline
#4 Posted : Sunday, 8 March 2009 9:04:19 AM(UTC)
ITCH
Ask DP , he knows all , so he thinks , HHAHAHAHAHA!
<b><font color="orange">&lt; 4 SALE , SELLING .......SOLD!</b></font id="orange">
#5 Posted : Sunday, 8 March 2009 6:43:22 PM(UTC)
As James says cluster gear is the best way. Whilst you cannot swap and change most input shafts some do work on others confusing the whole issue. James, cases for 3 and 4spd are different, only the early 4spds used the 3spd case.
______________________
308hjute Offline
#6 Posted : Monday, 9 March 2009 5:00:44 AM(UTC)
308hjute
Guys,
part number for the cluster gear (I think) for this box is
2813497 AG
Kev
#7 Posted : Monday, 9 March 2009 5:29:31 AM(UTC)
Kev, that cluster gear part number is the same as the VB-VK M21 cluster gear, ergo......
308hjute Offline
#8 Posted : Monday, 9 March 2009 5:53:14 AM(UTC)
308hjute
Thanks Mick,
Ill have a chat to you in the next week or so. Bought a tonner body to replace mine, and it had the box with it.
Allegedly a HQ tonner, but the cab is definitely a HZ or WB with absolutely minimal rust...... looks like there might have
#9 Posted : Monday, 9 March 2009 6:00:33 AM(UTC)
As Mick says, that cluster is for an M21 for HQ onwards. You dont really want an M21 in a tonner though. 1st gear is a b!tch when loaded unless you use a 3.55 diff.
If we all had the same (good)
308hjute Offline
#10 Posted : Monday, 9 March 2009 6:07:58 AM(UTC)
308hjute
HK,
Ive been running a 3.08 diff for the last couple of years in the old girl. Its not a work ute, only a cruiser.
Although having said that, we towed a car trailer up to Blackheath yesterday (Blue Mountains for those not familiar) from Campbelltow
#11 Posted : Monday, 9 March 2009 6:41:17 AM(UTC)
3 speed autos are great for towing. With 3.08 diff even better. But put an M21 in there and youll be changing clutches regularly even without towing. The last 1-tonner I built up was a WB, and at the time I had a spare 202 so I used it with an M20. It was
