Hi all I have decided its time for a power upgrade for the ute as everything else has now been done and the standard 308 just isnt cutting it anymore. The options which I have narrowed it down to are. 1.Staying with the 5.0 but goin fuel injected say a late vt engine and running a large single turbo and chasing about 400 rwhp.
2.Second option is goin with a small block chev and running the usual mods to get the desired hp.
Any feed back on this would be very helpful. The ute will only be a weekend car from now on and maybe the ocasional run down the strip so fuel economy is of no concern anymore. cheers
What gearbox and diff are in it now?
I sort of agree, but a 380-400 cube Holden or Chev small block may be a lot easier depending upon what is there now.
chev off road are making a new crank to make a big cube holden, cant remember the size 393 cube i believe
What about the Big Paw? Be a little unique? http://www.torque-power.com.au/big_paw11.htm
Holden based motor that can be taken to 500 cubes and bolt in place of any 253/308 Holden. So you get the grunt you want, and its a dead easy swap. Of course youl |
"Silly modern cars" |
Its still running the m21 and salisbury combo.But I,m thinking of putting a borg warner rear end in and maybe a supra 5spd.Not real sure on the box just yet
yep,we could to the above, get the C.O.M.E. big cube kit, and after you do all that, and spend all that money, you can get a ZZ502 or even a 502HO, brand new, that makes heaps more ft/lbs without even raising a sweat and on pump gas without a drama, for t
With an M21 or Supra and 10 bolt youll have to stay 308. Youll have to run a TH400 or 4spd TH400 and 9" if you want a 500hp engine.
_______________________________________________________ If we all had the same (good) taste, who would buy all the Ford |
Yeah right whats the go with these tremec 5spd gearboxs from Mal Wood they should handle 500hp.There are numerous cars running that sort of power with a manual box.No way am I goin Auto
I dont know much about Tremecs. A Muncie M22 will handle decent power, so will a properly built Toploader. These are what Id use if going manual, although a 4L80 would be my choice.
_______________________________________________________ If we all had |
the muncie is a good box, but getting a bit scarce now.
some of these newer 5 sp boxes have the shifter way back, like near where your seatbelts come out when they are put into holdens.
WANTED: HZ sandman Van 6/10 or better. |
Dont forget the Mighty "Super T-10 Transmission" Tuff as nails! |
 <b><font color="orange">< 4 SALE , SELLING .......SOLD!</b></font id="orange"> |
Thanks all for the feedback.Ive decided that I will be goin the small block chev.It just seems the best bang for my buck
Possibly. A stroked 308 might be a cheaper option for you so you can re-use radiator, exhaust, engine accessories, mounts etc.
SBC is a solid bet, but before you do, read Street Machine August and September 07. Bob Kotmels tech articles are entirely devoted to Red 308s. Different builds, specs, outputs etc. Great stuff. |
Yeah mate I have those issues of Street Machine and it is very good reading makes it hard to decide what the best way to go is.After looking on the net for the last few months I found that all the after market stuff for chevs seems to be a lot cheaper as
