states_man Offline
#1 Posted : Tuesday, 10 March 2009 5:14:39 AM(UTC)
states_man
Hi all
I will soon be removing my Girlock calipers and was thinking that I might be better off upgrading to PBR twin piston calipers as per late commodores. Would like to know some of the fors and againsts from some of you more experienced people.Also not sure that the new PBRs will be a direct replacement, has anyone found an adaptor plate on the market(dont really want a Hoppers kit as I already have rotors)
thanks
Brian
states_man Offline
#2 Posted : Wednesday, 11 March 2009 3:59:20 AM(UTC)
states_man
nearly 24 hours and no replies, there must be somebody out there that knows about this.
peter_flane Offline
#3 Posted : Wednesday, 11 March 2009 4:16:59 AM(UTC)
peter_flane
The HZ Girlock are very good caliper, are you still using 275mm rotor?
#4 Posted : Wednesday, 11 March 2009 4:19:33 AM(UTC)
Hi Brian.
I have done a few HQ-WB front brake conversions using VT-style front calipers & rotors, but most were done using Hoppers kits.
I can tell you a couple of specs though. The Commodore caliper will not bolt onto the early model stub axle, bec
states_man Offline
#5 Posted : Wednesday, 11 March 2009 4:23:31 AM(UTC)
states_man
thank you for your replies
might also need to mention that I need to stay with 4.75inch PCD as I have a nice set of 18 inch wheels on it
states_man Offline
#6 Posted : Wednesday, 11 March 2009 4:41:43 AM(UTC)
states_man
I am still using standard rotor so I might just stick with the girlocks and get them recoed/painted/polished and then put on the drilled rotors,
I dont have the hubs yet to suit the DBA rotors, where do I get these??
