RussVRute Offline
#1 Posted : Monday, 16 March 2009 1:43:46 AM(UTC)
RussVRute
Gday all,
The odometer on my VR ute has stopped working, the speedo still works fine. As far as I can tell from the manual, which really doesnt even touch on the odometer, everything is electronic and there is no cable like in the old days. Is this able to be fixed or do I have to replace the speedo altogether? There is a fuse, but, I suspect if that was the problem the speedo would not work at all. Is it all controlled by the main computer and could that be the problem? Any help or advice greatly appreciated. Thanks.
petaus Offline
#2 Posted : Monday, 16 March 2009 4:20:32 AM(UTC)
petaus
just be the odometer i think, they crap a gear in them from memory, you can take it out and get it repair,i think i have even seen the parts advertised on evil bay, search for a instrument place in your area, a secondhand cluster.
pete.
Blue ballz Offline
#3 Posted : Monday, 16 March 2009 8:35:17 AM(UTC)
Blue ballz
do a search on vs commodore on ebasy and should find it.
#4 Posted : Wednesday, 18 March 2009 9:18:16 AM(UTC)
Its a rubber gear that strips in your speedo. A new one should cost about $11.
VN-VS Commodores and EA EB ED Falcons all use this same gear and all have a habit of stripping them.
They are less prone to stripping if you only reset the trip meter w
RussVRute Offline
#5 Posted : Thursday, 19 March 2009 6:10:45 AM(UTC)
RussVRute
Thanks for the replies guys, I really appreciate it,considering the fact that I rarely get in here any more, and you were still willing to help me out. I have found one of the gears on eBay. Are they easy to fit or is it a whole weekend pulling the dash a
Blue ballz Offline
#6 Posted : Thursday, 19 March 2009 6:32:00 AM(UTC)
Blue ballz
Quite easy.Pull off the light switch and then get some long nose pliers and rotate out. You have two screws on the the top of the cluster as you look at the display. Short stubby screw driver, real easy. Get a fine screw flat tip and place around the surr
