sixx Offline
#1 Posted : Monday, 16 March 2009 4:51:53 AM(UTC)
sixx
well, this is probably a pretty simple question to answer but everyone has a different idea.
ok 351 clevo general driving round town temp sits on quarter to half. Twin thermos keep it cool, but if you take car out onto highway cruisin at 3000rpm 100km/phr temp starts to rise , doesnt get to hot but at least to close for comfort. car is straight gas, thermostat is new and 71 degrees, twin thermo el fans, 1 comes on at 90 degrees the other 100 degrees, 3 core radiator good condiion. could the water pump be the problem or blocked radiator?????
What thermostat should yopu run on 351 gas v8s
bambino Offline
#2 Posted : Monday, 16 March 2009 7:18:04 PM(UTC)
bambino
I had this problem once with a 302 XC, the thermo fans were fitted the wrong way ie. suck instead of blow. Make sure when it's idling that the fans blow the air over the motor not out through the radiator core.If they're the wrong way round they work fine
sixx Offline
#3 Posted : Tuesday, 17 March 2009 5:36:02 AM(UTC)
sixx
bambino-
yeh ive checked that, fans are currently sucking through radiator and blowing over motor. looks like im back to original theory blocked radiator or crapped out water pump.
302Superbird Offline
#4 Posted : Tuesday, 17 March 2009 6:22:41 AM(UTC)
302Superbird
Are you certain that it is overheating? Have you checked it with a infra-red thermometer or does it blow its lid? Mine is ZH 351 on Straight LPG, runs about half all the time, only creeps up in traffic and after switched off. I replaced my thermos with t
sixx Offline
#5 Posted : Tuesday, 17 March 2009 7:22:26 AM(UTC)
sixx
Superbird,
Im running a completely separate gauge to the factory one as i dont trust them. factory gauge will sit quarter off hot while crusin at speed while other gauge sits on 100degrees celsius. Car hasent boiled over yet but i am worried as weather
#6 Posted : Tuesday, 17 March 2009 8:25:08 AM(UTC)
302Superbird
Yeah, I beleive about 90-100. I live in Perth and drive it on near 40 degree days. Never missed a beat but I am a bit concerned too. When I pull up and put the infra-red on it, Generally about 90-95 degrees. Do you have anything in front of your radiator?
Henry Heaven Offline
#7 Posted : Wednesday, 18 March 2009 12:13:44 AM(UTC)
Henry Heaven
Is motor standard bore?A lot of clevo"s are bad for overheating once 30 thou or more,mate having same problem with his F150 on gas & after a lot of mods & swearing found this to be the problem
Regards Henry
sixx Offline
#8 Posted : Wednesday, 18 March 2009 4:29:38 AM(UTC)
sixx
Superbird - Henry Heaven;
Water pump is an aftermarket alloy one, brand unknown. the only thing in front of radiator is a auto trans cooler alloy, but it doesnt really restrict air flow.
Motor is 30 thou up, flat top pistons... big comp over 12;1 , car
#9 Posted : Wednesday, 18 March 2009 9:30:52 AM(UTC)
I might go out on a limb and ask if your total ignition advance is correct? Is your centrifugal advance working? This can cause hot running at higher revs.
landy351 Offline
#10 Posted : Wednesday, 18 March 2009 10:13:11 AM(UTC)
landy351
I have just replaced the waterpump on my Landau, and was told Dont fit an alloy pump to early Clevo'sby 4 different suppliers. Might be worth investigating.
sixx Offline
#11 Posted : Saturday, 21 March 2009 4:09:14 AM(UTC)
sixx
Ok , car has just been dynoed ignition curb is ok, alloy water pump has always been on car,...
Has anyone ever heard of the bottom radiator hose that has spring inside, if spring rusts the lower hose will suck flat at higher rpm therefore blocking your r
#12 Posted : Saturday, 21 March 2009 8:00:13 AM(UTC)
302Superbird
Yeah, I believe that is why the spring is in your lower hose, to stop it sucking in on itself. Never come across it but it sounds right?
xwute Offline
#13 Posted : Saturday, 21 March 2009 9:45:52 AM(UTC)
xwute
I was selling these vehicles when they were new. Complaints were made about the apparent overheating. The fix was to remove the gauge and bend the needle to show a lesser reading. Try that now with consumer laws.
bambino Offline
#14 Posted : Sunday, 22 March 2009 8:19:08 PM(UTC)
bambino
Yes, that used to be quite common in older Clevos. It's quite a while now since I had one and I forgot the obvious in my earlier reply, now that I think about it we used to change the hoses every year or so just for that problem.
XB351 Offline
#15 Posted : Monday, 23 March 2009 2:37:02 AM(UTC)
XB351
sixx Offline
#16 Posted : Monday, 23 March 2009 7:21:29 AM(UTC)
sixx
Well looks like i may have found the problem, upon inspection of lower hose, the coil spring inside had moved right back up to water pump leaving about a 200mm gap at radiator end which could quite easily suck flat. I could flatten it with a soft squeeze.
Tucker Offline
#17 Posted : Monday, 23 March 2009 10:59:58 PM(UTC)
Tucker
Hi there,
Can anyone advise me as to what their thoughts are?
I bought a 94 Fairlane V8 on gas and petrol with a new radiator, water pump and header tank. If you drive the car for more than about 10 kms at speeds over 60kph the temp slowly rises to the
XB351 Offline
#18 Posted : Saturday, 28 March 2009 7:48:52 PM(UTC)
XB351
Originally posted by Tucker
Hi there,
dicko74 Offline
#19 Posted : Tuesday, 12 May 2009 2:40:40 AM(UTC)
dicko74
gday, i own a landau and im chasing a rear window and trims. is there any one out there who knows of one.
Paul351xb Offline
#20 Posted : Tuesday, 12 May 2009 5:56:44 AM(UTC)
Paul351xb
check ebay or try superoo in WA. XA to XC coupes have the same rear glass. Glass is easier to find than the stainless trim with the trim often costing quite a few hundred dollars.
Almost forgot. XA and early XB coupe will not have a rear demister an
Edited by user Tuesday, 12 May 2009 6:03:38 AM(UTC)  | Reason: Not specified
Guest (12)
This page was generated in 0.110 seconds.
