#1 Posted : Tuesday, 29 April 2008 8:26:34 AM(UTC)
Are all the brackets and compressors for a 253 and 308 the same all the way through from hj to wb i have a hz and looking for the parts that bolt onto the motor and have found plenty of wb stuff is it all the same ??? cheers Dazza
#2 Posted : Tuesday, 29 April 2008 6:01:00 PM(UTC)
Hi Dazza.
The brackets are all the same. There are some other minor differences though.
One of the changes many forget when fitting a/cond is that the water pump pulley is different (smaller diameter & machined from billet). Most WB V8s use the Ju
#3 Posted : Tuesday, 29 April 2008 6:01:00 PM(UTC)
Hi Dazza.
One of the changes many forget when fitting a/cond is that the water pump pulley is different (smaller diameter & machined from billet). Most WB V8s use the 'J
musksell Offline
#4 Posted : Tuesday, 29 April 2008 8:29:13 PM(UTC)
musksell
I think he meant was there different air cond compressors, of which I think there were two the GM or harrison and the vastly superior Sanken (japanese) which are mounted in different places.The Sanken uses less fuel to drive.....I believe
#5 Posted : Tuesday, 29 April 2008 11:06:00 PM(UTC)
HI muskell.
If you're talking factory-fitted a/cond, there is only one compressor, the GM A6. That's the the big black one which is variously branded Fridigaire, Delco or Harrison. The common one fitted to most Holdens was 12 cubic inches.
The GM P
#6 Posted : Tuesday, 29 April 2008 11:06:00 PM(UTC)
HI muskell.
If youre talking factory-fitted a/cond, there is only one compressor, the GM A6. Thats the the big black one which is variously branded Fridigaire, Delco or Harrison. The common one fitted to most Holdens was 12 cubic inches.
The GM P&A
#7 Posted : Tuesday, 29 April 2008 11:10:30 PM(UTC)
1
Edited by user Wednesday, 30 April 2008 2:29:20 AM(UTC)  | Reason: Not specified
#8 Posted : Saturday, 3 May 2008 4:50:52 AM(UTC)
Thanks guys for the replies helps alot
This page was generated in 0.080 seconds.
