roy1126 Offline
#1 Posted : Wednesday, 18 March 2009 9:54:10 AM(UTC)
roy1126
Hi all
Project HZ is slowly moving along. In the 308 rebuild stage at the moment.
Cranks in, rods and pistons are in and the heads are on. Now I was going to put the cam and timing gear in before I put the heads on but ..........forgot.
So, the question is, whats the best way to find TDC of #1 cylinder when the heads are on?
Roy
#2 Posted : Thursday, 19 March 2009 5:50:45 AM(UTC)
take the spark plug out of no 1, put a screw driver in and turn the motor by hand til the screw driver stops coming up and starts going down, then it at tdc
if it wasnt for the last minute id get nothing done
JBM Offline
#3 Posted : Thursday, 19 March 2009 6:01:38 AM(UTC)
JBM
Is the cam and valvetrain in place?
If your looking for TDC to put the timing chain on you can use the timing marker near the balancer as well.
To set ignition timing you need TDC on the compression stroke, piston at top and both valves closed. You
Edited by user Thursday, 19 March 2009 6:04:43 AM(UTC)  | Reason: Not specified
roy1126 Offline
#4 Posted : Thursday, 19 March 2009 6:24:44 AM(UTC)
roy1126
Thanks for the replies.
No the cam and valve train arent in yet.
Roy
petaus Offline
#5 Posted : Thursday, 19 March 2009 7:31:52 AM(UTC)
petaus
see if you can mount a dial indicator through number one plug hole, adjust it so you can turn the engine over with out locking it up, mount a piece of wire from behind the head of any bolt,slip balancer on and line up wire to a place on balancer, ok now t
