HQforme Offline
#1 Posted : Thursday, 19 March 2009 9:57:36 AM(UTC)
HQforme
Whilst im rebuilding my motor after finding glazed bores, was going to do the new high comp head i have, but looking at the head i have on it, which took a fair little bit of time to do, i think i'll just tickle the ports a bit more and shave it down, while i spend time doing the new head really well. This was my first ever attempt at porting.
Edited by user Thursday, 19 March 2009 9:58:21 AM(UTC)  | Reason: Not specified
"Silly modern cars"
pont69 Offline
#2 Posted : Friday, 20 March 2009 5:41:16 AM(UTC)
pont69
wow.. that makes a hell of a difference..
Im just getting another head to put bigger valves etc on.. wee how that goes.. and i might try some proting like this :)
Cheers, James
Cheers, James
vintageholden Offline
#3 Posted : Friday, 20 March 2009 6:02:58 AM(UTC)
vintageholden
http://www.bur.st/~oljohnno/holden.html#C5
good section here on how to port
HQforme Offline
#4 Posted : Friday, 20 March 2009 7:43:27 AM(UTC)
HQforme
Ive seen that, cheers. Pretty much what i did, but theres always room to improve and ill be trying some of that in the next head!
"Silly modern cars"
Sandman Offline
#5 Posted : Monday, 23 March 2009 9:00:50 AM(UTC)
Sandman
Cut the post out of the intake port that the head bolt goes thru.
Get a recessed hole milled into the bottom of the port to use an Allen head bolt for a head bolt.
Then get it drilled and tapped thru the top of the port to plug it.
When finished, smoo
