HJHeaven Offline
#1 Posted : Sunday, 22 March 2009 7:29:47 AM(UTC)
HJHeaven
Hi
A friend of mine has what he thinks is a a genuine XU-1 motor (186 block) with which has had some work (yella terra heads, cane manifold, high volume oil pump, triple SUs and 202 crank).
About 2k since rebuild.
I understand that it is a very good motor.
Two questions:
1. What do you guys think something like this would be worth if genuine; and
2. How can you identify that it is a genuine XU-1 motor?
Thanks again guys
Mark
I am not allowed a mistress so i got a GTS - and its better
A GTS/4 is a monaro - so nuuur
Casper Offline
#2 Posted : Sunday, 22 March 2009 8:04:27 AM(UTC)
Casper
Engine number should start with 3100X
David Offline
#3 Posted : Sunday, 22 March 2009 9:22:39 AM(UTC)
David
I think a few early XU1 motors started with 186X. Not sure how many.
vintageholden Offline
#4 Posted : Sunday, 22 March 2009 1:59:18 PM(UTC)
vintageholden
186 as fitted to XU-1 from Aug 1970 Aug 1971
Engine prefix code: 3100X
186 Bathurst as fitted from Sept 1971 Jan 1972
Engine Prefix Code: CK
Six cylinder engines: located stamped on a pad above the engine mount bosses on right hand side
Edited by user Sunday, 22 March 2009 2:00:58 PM(UTC)  | Reason: Not specified
#5 Posted : Sunday, 22 March 2009 6:59:49 PM(UTC)
If it is an LC XU-1 block, send a PM to 3100X (look in the members section). He is looking for one.
HJHeaven Offline
#6 Posted : Monday, 23 March 2009 5:34:54 AM(UTC)
HJHeaven
Sorry
False alarm - it is a HG red 6.
I think he is still loooking to sell through.
#7 Posted : Monday, 23 March 2009 6:11:16 AM(UTC)
vintageholden
186p.......
