009pk Offline
#1 Posted : Friday, 27 March 2009 3:55:16 AM(UTC)
009pk
Am looking at installing 308 motor and auto box out of vc commodore
into lx torana sedan would anybody know what mods would be required
or extra parts required to complete conversion
#2 Posted : Friday, 27 March 2009 4:18:05 AM(UTC)
Only thing that you have to change is sump, pickup, dipstick and exhaust manifolds.
3100x Offline
#3 Posted : Friday, 27 March 2009 10:49:48 AM(UTC)
3100x
you may have to look at the polution gear as in some states
the rules follow the motor used in transplants,
original carby and airfilter for that motor etc
#4 Posted : Friday, 27 March 2009 5:39:23 PM(UTC)
That is correct, but if the engine is complete it will all be there. If its a pre 6/76 LX youll just need the later LX/UC Canister and kickdown wire/switch on the gearbox. If you are really unlucky theyll make you fit the exhaust manifolds of a later LX w
classic oz wreck Offline
#5 Posted : Friday, 27 March 2009 8:01:53 PM(UTC)
classic oz wreck
__do
www.classicozwreck.com.au
#6 Posted : Friday, 27 March 2009 10:37:40 PM(UTC)
Greg is correct about the mounts etc. but you might get away with the different water pump & pulleys on the Blue V8. Depending on what engine fan you are running, you may only need to alter the fan spacer. It all depends on how much room you end up with b
#7 Posted : Saturday, 28 March 2009 2:07:49 AM(UTC)
Yes I forgot about the engine mount adapters, but Id leave the blue water pump and pulleys as that is exactly what Id put on a red motor anyway.
The other thing to be wary of is what bellhousing pattern the 308 is. This will dictate what gearbox you us
Guest (5)
