i have a hz ute rusty so i want to swap bodys am i allowed to drill out the rivits so the plates still match the paper work???? if so how , and what rivits .......................NOTE TO DARRYL........................ what if i was restoring it and wanted to paint under the rivits not everyone is a crook..fraud.... KEEP NEGATIVE THOUGHTS OFF THIS WEB SITE.... Edited by user Thursday, 2 April 2009 9:52:30 AM(UTC)
| Reason: Not specified
you use to be able to buy the riviting kits from ebay
if it wasnt for the last minute id get nothing done
Whats with the DUMB question? Wouldnt you check with the relivent state registration body or are you trying to rebody stolen cars? Sounds like the later to me.
Years ago no problem. Nowadays it seems to be a touchy subject. Personally I see no problem with it - a body is as much a spare part as a guard. But you arent supposed to remove the ADR tag. Noot sure how you do a rust reppair on the cowl though without r |
Imagine if he was talking about a Monaro body! Cmon fellas speak up! :) |
It is a bit different to a pre 1970 Monaro, as on the HZ the identity of the car as far as the Police and registry are concerned is on the chassis. With the HK and pre 1970 HT the sole identity of the car lies with the actual body shell not the rails. So |
assuming of course there is no firewall/cowl number on the donor or original shell???????Whats this crapp. Why not go down the right avenue and do it correctly within state laws. There is already too many thieving a##holes around and telling them how to d
Whats with the DUMB question? Wouldnt you check with the relivent state registration body or are you trying to rebody stolen cars? Sounds like the later to me. thanks for the possitive help mate...the forum needs more people like you........ would y Edited by user Thursday, 2 April 2009 9:31:10 AM(UTC)
quote: Originally posted by darryl
assuming of course there is no firewall/cowl number on the donor or original shell???????Wh |
You will find there is quite a good reason for the law. It is very easy, you cannot remove a compliance plate (the one with the adrs and chassis number on it, not the other tags) from a vahicle.
Now we all know that for some models it is quite "normal"
Warren, read again what I suggested. There are no laws broken.
as long as the Chassis rail number matches the ADR tag chassis number, i dont see any problem. its not the same argument as HKTG for this reason.
WANTED: HZ sandman Van 6/10 or better. |
Adam, I agree but we must remember that removing an ADR tag is the problem, ie not exactly legal.
Thanks: 8 times Was thanked: 16 time(s) in 14 post(s)
i asked a real policeman who deal with rebirths etc, and i was told the only way this was legal was if the donor shell was in fact a "spare part" and did not already have an adr tag attached.
How many of these "spare parts" have you seen on Egay?
Yo
Without wanting to get too pedantic, is it technically illegal to remove a compliance plate for the purpose of re-painting, repairing or restoring a car & then re-fit it to the same car using the correct rivets. Most people would never know (or care), but |
To vintageholden, you said you wanted to swap bodies NOT paint under the rivets. Get it right. And as for the laws they are there for a reason, to try and keep people honest. Like I said, you choose which catergory you fall into. And as for the negative t
dr terry, id like to know the same thing
i am currantly restoring a hq ambulance, the rust in the firewall/cowl panel/plemnum is quite bad, there is a large hole right next to the pass side id plate and i was going to remove the tag to repair the rust
hahaha, what a joke. there is 4 ways of getting caught doing something shifty or just doing anything that some people regard as wrong. 1/ tellafriend 2/ tellaphone 3/ tellawoman 4/ TELLAGRAM If you are going to do something like what vintage is go Edited by user Friday, 3 April 2009 4:09:19 AM(UTC)
