mrstubb Offline
#1 Posted : Saturday, 4 April 2009 5:54:39 AM(UTC)
mrstubb
The 4R55E transmission in 1998 Explorer 4X4 went out. I bought another one from a salvage yard. When I dropped the pan I found this:
A transmission shop looked at it & said it was a bearing. I still have the original transmission. Can I remove the part from it and put it into new transmission? Or how do I make one good transmission from the two? I would also like to know where I can find rebuild instructions, torque specifications, details of component locations, and diagrams for this transmission.
302Superbird Offline
#2 Posted : Wednesday, 8 April 2009 6:23:49 AM(UTC)
302Superbird
Hi there. Yes, it looks like a needle roller bearing? Where is the rest of it? I reckon you need to speak to a ford tranny specialist as the Explorer would not really be a common talked about vehicle.
Have you googled it find out more info as a tranny i
#3 Posted : Friday, 10 April 2009 9:14:32 AM(UTC)
That is called a torrington bearing (or at least in your case 1/4 of one).
Firstly I would take the transmission back to the salvage yard for a refund. If you cant do that then I would try to pull this torrington bearing out of your old transmissio
