vphunni Offline
#1 Posted : Wednesday, 8 April 2009 11:34:18 PM(UTC)
vphunni
Hi everyone,
Ok, so the other night had been driving for a few hours. The battery light was on the whole way (I just figured it was probably the terminals). The car then started to lose power I guess. The stereo was going on and off. The indicators then stopped working. The dash lights went dim. The head lights were playing up.
I pulled into a servo turned the car off and it would not start again. so I brought a new battery so I could make it home.
Ever since the battery light has mostly not been on, but does come on a few times a day but not for very long.
Is it the alternator?
Do I need a new one?
I think a friend told me it could be the bushs?
What should I do?
Thanks guys,
vphunni
#2 Posted : Wednesday, 8 April 2009 11:52:30 PM(UTC)
vphunni Offline
#3 Posted : Wednesday, 8 April 2009 11:55:38 PM(UTC)
vphunni
Thanks Dr.Terry you rock!!!
Last time I asked about my engine light everywhere and couldnt get an answer.
Holden couldnt even fix the problem and you told me to try a new computer..it worked!!!
So thank you VERY VERY much.
Will give this a try.
basketcasebear Offline
#4 Posted : Thursday, 9 April 2009 3:43:49 AM(UTC)
basketcasebear
just thought i would throw my bit in?
because with new battery in, the batt light, can on sometimes??
could this be something else?? rather than alternator?
if alt was cactus, would it not be still on with new battery,
just a thought.
bcb
DOH!!!
3100x Offline
#5 Posted : Thursday, 9 April 2009 6:12:10 AM(UTC)
3100x
when the brushes are marginal the connection can vary and
change with vibration, bumps etc, thus the altenator will
work at times and light will go off
vphunni Offline
#6 Posted : Friday, 10 April 2009 12:55:28 AM(UTC)
vphunni
hey all,
replaced the voltage regultor and it is fixed!!!!
Thanks 4 everyones contributions.
vphunni
#7 Posted : Monday, 13 April 2009 10:54:52 PM(UTC)
Just changed the brushes in mine, gen light just starting to light up.
What I noticed was the old brushes had hardly any ware, compared to the VN ones that use about 75% of the brush before they stop, these were less than 10%. So they may have chnaged
