thisISjoel Offline
#1 Posted : Thursday, 9 April 2009 10:53:54 PM(UTC)
thisISjoel
Hey Guys
Hoping someone can help me out here I have a 2000 Holden Astra and recently the Air Bag warning light has come on.
Does anyone know what this might indicate and whether or not I need to take the car to a Holden service centre or if I can use any auto electrician?
Thanks for any input.
#2 Posted : Thursday, 9 April 2009 11:31:32 PM(UTC)
Any automotive technician who has the appropriate scanner can diagnose the fault.
The most common airbag faults on Astras are the clock-spring & the seatbelt pre-tensioners.
thisISjoel Offline
#3 Posted : Friday, 10 April 2009 12:30:22 AM(UTC)
thisISjoel
Thanks mate!
Foegive my ignorance but what are seatbelt pre-tensioners and do you know how expensive this problem usually is to fix?
#4 Posted : Friday, 10 April 2009 1:33:05 AM(UTC)
Seatbelt pre-tensioners are usually part of the buckle assembly between the front seat & the centre console. 2nd hand ones are OK to use, if thats the problem.
Often they need nothing more than having their fault codes erased, so see a tech first.
D
thisISjoel Offline
#5 Posted : Friday, 10 April 2009 1:53:35 AM(UTC)
thisISjoel
Thanks again!
