DreaminHR Offline
#1 Posted : Friday, 10 April 2009 12:41:23 AM(UTC)
DreaminHR
BEING THE TOOL THAT I AM i realised today i have put my stub axles on the wrong sides ie: my calipers would be at the back not the front. Now when ive tried to fix my stupid mistake i cant get the stub axle off the upper ball joint, ive tried jacking it and smacking it with a rubber mallet (leaving my head with a massive lump) but nothing has worked. would i be better to take the whole upper swing arm to pedders n get em to undo my dick head mistake or is there a trick i dont know about. any help would be awesome
classic oz wreck Offline
#2 Posted : Friday, 10 April 2009 1:32:11 AM(UTC)
classic oz wreck
you generally need to hit it with a real hammer...rubber is no good...
www.classicozwreck.com.au
DreaminHR Offline
#3 Posted : Friday, 10 April 2009 2:01:05 AM(UTC)
DreaminHR
yeah ill have to source out a hole punch so i dont damage the thread on the balljoint.
#4 Posted : Friday, 10 April 2009 4:16:03 AM(UTC)
No you put the nut back on the balljoint a couple of threads to protect the thread and you belt the stub axle area where it surrounds the ball joint taper. Two or three good hits should do it.
Utility8 Offline
#5 Posted : Friday, 10 April 2009 5:19:26 AM(UTC)
Utility8
Also, dont jack up the lower control arm, the ball joint releases more easily if under tension. MAKE SURE that the ball joint nut is loosened but still on as Jim5.0 mentioned to protect the thread & also you.
Utility8
[img]http://forum.ejehclubqld.com
utility8
vintageholden Offline
#6 Posted : Friday, 10 April 2009 5:42:16 AM(UTC)
vintageholden
hit each side of the stub axle at the same time, near the ball joint to shock it off,
you need 2 hammers.......
keep the ball joint undr preasure from the spring to push it off......
DreaminHR Offline
#7 Posted : Friday, 10 April 2009 5:52:05 AM(UTC)
DreaminHR
ill see how i go with it in the morning, hoping to get her front wheels back on too.
thanks fellas
#8 Posted : Friday, 10 April 2009 7:01:59 AM(UTC)
just belt it on the sides on the stub, not the ball joint. also you can use a pinch bar to lever it down to help a bit.
the other day i refitted a manual steering box to a HQ. all i did was tighten up the castellated nut, put the split pin through and le
