HKGTS186S Offline
#1 Posted : Sunday, 12 April 2009 11:45:50 AM(UTC)
HKGTS186S
Hi can anyone tell me what a 69 - 71 Saginaw gearbox numbers should be ?
HKGTS186S Offline
#2 Posted : Sunday, 12 April 2009 10:28:40 PM(UTC)
HKGTS186S
Can anyone help with casting numbers on a saginaw ?
#3 Posted : Monday, 13 April 2009 12:50:35 AM(UTC)
68-69 3925647 on main case, muncie was used after Aug 1969 for all AMERICAN GM V8, not aussie though
Edited by user Monday, 13 April 2009 2:08:57 AM(UTC)  | Reason: Not specified
#4 Posted : Monday, 13 April 2009 4:20:00 AM(UTC)
Frank they are the numbers for Three speed Saginaw main case.
www.monaromuscleparts.com
#5 Posted : Monday, 13 April 2009 4:31:07 AM(UTC)
top of me head stuff that was, ill have a proper look after and double check and fix
#6 Posted : Monday, 13 April 2009 7:11:54 AM(UTC)
Are you sure Frank? I thought you were an 81837 Wrecker not a Vega wrecker ? Who would have the three speed numbers stuck in the top of his head as there would be hardly any even in this country ? Maybe we should catch up for Gelati some time and we can
HKGTS186S Offline
#7 Posted : Monday, 13 April 2009 7:52:51 AM(UTC)
HKGTS186S
Numbers read 29 5868 have been told it was a saginaw ? ?
#8 Posted : Monday, 13 April 2009 8:48:12 AM(UTC)
#9 Posted : Monday, 13 April 2009 9:14:08 AM(UTC)
Oh Come on Frank thats a bit harsh , i never have or never would say i was the best Monaro bloke out . Now you are baiting me . I just do what i can . There is a reason i will not post up the numbers for the saginaw ,i will tell you why when we catch up f
#10 Posted : Monday, 13 April 2009 9:34:42 AM(UTC)
what me bait you or anyone else???? no way...
somehow, i dont think the discussion would last long enough for you to explain your secrecy about the numbers james...
HKGTS186S Offline
#11 Posted : Monday, 13 April 2009 9:36:40 AM(UTC)
HKGTS186S
So can anyone verify those numbers ?
#12 Posted : Monday, 13 April 2009 9:45:30 AM(UTC)
Back to top
HKGTS186S Offline
#13 Posted : Monday, 13 April 2009 10:17:26 AM(UTC)
HKGTS186S
no worries
hazzard county Offline
#14 Posted : Monday, 13 April 2009 5:27:10 PM(UTC)
hazzard county
hey hk the main case is 3925654 & the tail housing is a 3 speed tail housing 3873885 which has no mount holes at the rear for the american hurst shifter hope this helps
Edited by user Monday, 13 April 2009 5:31:25 PM(UTC)  | Reason: Not specified
HKGTS186S Offline
#15 Posted : Monday, 13 April 2009 9:44:34 PM(UTC)
HKGTS186S
Thanks mate , this one is supposed to be out of a ht/hg I believe ?
shifty350 Offline
#16 Posted : Thursday, 16 April 2009 7:23:12 AM(UTC)
shifty350
Hello HKGTS186S,
The numbers quoted so far are close but not correct.
3925656 is the main case number
3860042 is the extension housing number
3920798 is the side cover number
There were two Saginaws used in Holdens. Both are identical externall
#17 Posted : Thursday, 16 April 2009 8:17:05 AM(UTC)
Originally posted by shifty350
Hello HKGTS186S,
3925656 is t
#18 Posted : Thursday, 16 April 2009 8:30:58 AM(UTC)
You are a laugh Frank i tell you . Since we are not going to now catch up for gelatis , i will tell you the funny story is i was going to bid on the saginaw on ebay which just sold by a Fastlane member (Chris Username Cannon on here ) which i missed out o
Edited by user Thursday, 16 April 2009 8:31:44 AM(UTC)  | Reason: Not specified
#19 Posted : Thursday, 16 April 2009 8:33:59 AM(UTC)
cannon is me mate...
and we will NEVER share the treasured moments of a gelati...
#20 Posted : Thursday, 16 April 2009 8:38:15 AM(UTC)
But Scott im your father ! Give daddy a hug !!!
If we did ever have gelati Frank , do you think we would sing "weve only just begun " by Karen Carpenter?
Guest (10)
