bundybluedog Offline
#1 Posted : Monday, 13 April 2009 6:20:43 PM(UTC)
bundybluedog
Out of the 179 186 and the 202 which engine is better to work? i have heard the 179 and 186 rev better but the 202 has more torque. not looking for a drag car engine just a fast fun cruiser. what parts are interchangable on these engines.
Gary Thorpe Offline
#2 Posted : Monday, 13 April 2009 6:26:41 PM(UTC)
Gary Thorpe
wow ... this should be interesting :)
My 2 bobs worth is that the 202 was primarily a workhorse motor and thus your previous note is correct re its torque etc.
I had a 202 in an LX Torana that went well but sucked more fuel than the 253 we replaced
Edited by user Monday, 13 April 2009 6:27:42 PM(UTC)  | Reason: Not specified
Gary T
HQforme Offline
#3 Posted : Monday, 13 April 2009 9:11:48 PM(UTC)
HQforme
If youre after a nippy cruiser, go the 202. The extra cubes and torque will make for a faster car in the real world. Lets be honest, you dont drive down the street at 6grand plus (often, haha) and so for normal, spirited driving, from say 2-5500 rpm, a ni
"Silly modern cars"
lxtoranahzute Offline
#4 Posted : Tuesday, 14 April 2009 12:14:03 AM(UTC)
lxtoranahzute
Is there any diffrence between the 202 and the 3.3
Mr Void Offline
#5 Posted : Tuesday, 14 April 2009 1:38:41 AM(UTC)
Mr Void
202CC = 3.3L No they are the same.
Im a 202 fan so Im not going to comment.... but then again Im also a turbo fan so if you are after some fun, well, like I said - Im not going to comment ; )
___________________
Why are you reading this, you shou
___________________
#6 Posted : Tuesday, 14 April 2009 4:48:17 AM(UTC)
202 everyday for a street car.
vintageholden Offline
#7 Posted : Tuesday, 14 April 2009 4:58:59 AM(UTC)
vintageholden
202 and 3.3 are a bit different
3.3 is blue motor with 12 port head , balanced crank, starfire rods....a better motor by far than a 202
Edited by user Tuesday, 14 April 2009 5:46:53 AM(UTC)  | Reason: Not specified
peter_flane Offline
#8 Posted : Tuesday, 14 April 2009 5:05:03 AM(UTC)
peter_flane
My 3.3 red from a HZ is 9 port originally. So 3.3 does not mean 12 port.
So many variables, what you want, what you afford, what you get, what you believe, what happens, what doesent, what is real, what isnt.
Search old posts will be helpful as this
Gary Thorpe Offline
#9 Posted : Tuesday, 14 April 2009 5:48:54 AM(UTC)
Gary Thorpe
2 more bob
if it has a straight 6 in it already then the Blue 3.3 or even better ... black 3.3 with EFI is the best change over... similar internals to the reply by Vintage.
At the end of the day YOU need to determine what kind of drivability you wa
Edited by user Tuesday, 14 April 2009 6:03:00 AM(UTC)  | Reason: Not specified
Gary T
#10 Posted : Tuesday, 14 April 2009 6:02:06 AM(UTC)
vintageholden
i didnt know that. i thought 3.3 were blue
never seen 3.3 red...only 202 red????
you learn something new everyday
#11 Posted : Tuesday, 14 April 2009 7:35:36 AM(UTC)
lh/x toranas had 3.3 red motors so did hz and vb commies
if it wasnt for the last minute id get nothing done
#12 Posted : Tuesday, 14 April 2009 7:43:48 AM(UTC)
Originally posted by colby
basicly a 3.3 only came out in a comerdoor so they where onley maid for aoto matics the way
#13 Posted : Tuesday, 14 April 2009 12:39:15 PM(UTC)
lxtoranahzute
[quote]Originally posted by colby
basicly a 3.3 only came out in a comerdoor so they where onley maid for aoto matics the way to tel the difrance is they have lotts of hosers so if u have a manuel u r beter of with a 186 witch came o
#14 Posted : Tuesday, 14 April 2009 4:53:35 PM(UTC)
And commodores also had manual transmissions.....
The only exceptions being the blue 3.3L in VC & VH were auto-only in NSW, and the EFI VK was auto only.
A lot of pe
#15 Posted : Tuesday, 14 April 2009 4:58:55 PM(UTC)
It depends what you call a 3.3.
The block ID changed from 202 to 3.3 in mid-1979, part-way thru VB, HZ & UC series. But the 3.3 name & badging began at the start of those same three model series.
The 3300 name & badging began at the beginning of the
Edited by user Tuesday, 14 April 2009 5:44:46 PM(UTC)  | Reason: Not specified
#16 Posted : Wednesday, 15 April 2009 2:20:25 AM(UTC)
bundybluedog
I have a mate with a duggan head in his shed for a red motor i live down the road from lakeside and they have opened it up again so wild could be fun.
whats the most power anyone has got out of a holden straight 6 naturaly aspirated?
Mr Void Offline
#17 Posted : Wednesday, 15 April 2009 5:13:21 AM(UTC)
Mr Void
___________________
colby Offline
#18 Posted : Wednesday, 15 April 2009 5:34:06 AM(UTC)
colby
the best holden6 is akshely the 179HP the HP is a verry rear moter it stans 4 HiGh PeRfOrMaNcE it cam out in the ehs4 and sum HiGh PeRfOrMaNcE xu1 terans and gts manaros. u can tel its a hp on the side of the moter it has HP insted of 197 they hav got a s
Rock_Lobster Offline
#19 Posted : Wednesday, 15 April 2009 7:06:25 AM(UTC)
Rock_Lobster
Read this : http://www.bur.st/~oljohnno/holden.html#C5
OR
Listen to COLBY. Your choice.
Wayne
kraul Offline
#20 Posted : Wednesday, 15 April 2009 8:05:38 AM(UTC)
kraul
is it not possible to remove people from this foroum who only talk s#&t???
i enjoy coming on and reading factual information not crap.
I think we know what im talking about
Guest (8)
This page was generated in 0.204 seconds.
