the Blue Light Offline
#1 Posted : Tuesday, 14 April 2009 5:04:27 AM(UTC)
the Blue Light
Hey people,
Has anyone tried to put the Bosch BXH1250A alternator into an older engine? Im trying to find a higher current alternator for the HZ and thought that this might do the trick if I could make a bracket up. I think these ones were in the VS Commodores. I've installed so much crap in my car that the 85A job is in danger of being maxed out.
Is this do-able or am I missing something glaringly obvious here?
petaus Offline
#2 Posted : Tuesday, 14 April 2009 6:27:45 AM(UTC)
petaus
have you spoken to a sparky? they might be able to put the guts of the higher amp one into your housing easy neat, or maybe even beef yours up?
pete.
playwme Offline
#3 Posted : Tuesday, 14 April 2009 6:40:41 AM(UTC)
playwme
Originally posted by colby
cheak yur fan belt mate if the fan belt is sliping u wont get all the curant to the fuse box
#4 Posted : Tuesday, 14 April 2009 7:21:52 AM(UTC)
So I guess youre already using a VN-VS 85A Bosch alternator?
The 85A ones are more than up to the task of powering a VS caprice with all the power doo-dads, EFI, electric thermo fan(s), climate control, 340W of headlights & foglights (on high beam with
basketcasebear Offline
#5 Posted : Tuesday, 14 April 2009 7:58:27 AM(UTC)
basketcasebear
hey yall
will a 120 amp alternators charge a battery faster? than a 65amp one?
just wondering.
bcb
said the weathercock to the wind,> "how tedious and monotonous you are, can you not blow in any other direction, but in my face!"
an
DOH!!!
Casper Offline
#6 Posted : Tuesday, 14 April 2009 8:20:04 AM(UTC)
Casper
You will need a 120amp battery to hold the extra juice or 2 x 65amp batterys coupled together
Colby
#7 Posted : Tuesday, 14 April 2009 8:22:54 AM(UTC)
the Blue Light
It is an 85A alternator according to the stamp, the exact model I cant tell. I assumed it was the Bosch replacement for the original unit, like a BXU1285A or something, which was not what went in to the VN - VS?
Its not really for my stereo, as that do
This page was generated in 0.111 seconds.
