hgkid1 Offline
#1 Posted : Saturday, 18 April 2009 2:19:26 AM(UTC)
hgkid1
I am building my 186 EFI motor and have put the head on and put the inlet manifold on without a hitch then went to put the extractors that came off the motor back on and they dont line up any more the 2 ends have somehow been pushed inwards it seems,
what can i do? are they repairable or stuffed? it seems a waist to throw them out but i dunno what to do about it,
any suggestions?
Mr Void Offline
#2 Posted : Saturday, 18 April 2009 4:26:07 AM(UTC)
Mr Void
bend them back out. If you are handy with an oxy then heat them first and gently pull them out till they fit.
If they copped a bang/squeeze while being stored they cause have easily been squashed. Youll probably be able to bend them by hand & leg but
___________________
Utility8 Offline
#3 Posted : Saturday, 18 April 2009 5:06:59 AM(UTC)
Utility8
Are the extractors the correct ones for the head you are using? Blue/black extractors are different to the red motor extractors. Bending them back may always give a problem of leaking at the head face gasket after a while. Fixing that sort of leak is not
utility8
vintageholden Offline
#4 Posted : Saturday, 18 April 2009 6:38:41 AM(UTC)
vintageholden
true..
are they 12 port
efi heads are....take them off and check with a gasket
hgkid1 Offline
#5 Posted : Saturday, 18 April 2009 11:29:40 AM(UTC)
hgkid1
yes they are 12 port they are the ones that came factory with the vk efi motor i believe, they came off the same head im using i think like Mr.void said they have been bumped or squeezed while they were in storage i know they are the correct extractors as
Edited by user Saturday, 18 April 2009 11:31:04 AM(UTC)  | Reason: Not specified
