I need engine mount brackets, (that bolt to the block). Will HQ-HZ fit a HG?
i have a set of unused HT HG rubber engine mounts but not the part that bolts to the block if your looking. |
Havent you learnt anything from that guy that gives sermons at church?...Captain whats his name. |
As the good doctor says you can use the HQJXZ type engine mounting and rubber block in a HG. The actual HG type engine mounting and rubber block are different.You can,t mix and match HQ and HG.
The only thing i found when i put a HJ motor into my HG, was that the motor sat lower in the engine bay (using HJ mounts). It kinked the lower radiator hose a little bit (on the stabaliser bar) but never caused any problems. If anything i was able to fi
