81837 Offline
#1 Posted : Friday, 24 April 2009 2:50:05 AM(UTC)
81837
I need engine mount brackets, (that bolt to the block). Will HQ-HZ fit a HG?
#2 Posted : Friday, 24 April 2009 3:24:20 AM(UTC)
Yes.
bundybluedog Offline
#3 Posted : Friday, 24 April 2009 4:41:45 AM(UTC)
bundybluedog
i have a set of unused HT HG rubber engine mounts but not the part that bolts to the block if your looking.
BREDBO Offline
#4 Posted : Friday, 24 April 2009 7:57:57 AM(UTC)
BREDBO
As the good doctor says you can use the HQJXZ type engine mounting and rubber block in a HG. The actual HG type engine mounting and rubber block are different.You can,t mix and match HQ and HG.
AGRO Offline
#5 Posted : Tuesday, 28 April 2009 6:21:30 AM(UTC)
AGRO
The only thing i found when i put a HJ motor into my HG, was that the motor sat lower in the engine bay (using HJ mounts).
It kinked the lower radiator hose a little bit (on the stabaliser bar) but never caused any problems.
If anything i was able to fi
