BREDBO Offline
#1 Posted : Friday, 24 April 2009 8:20:03 AM(UTC)
BREDBO
I am about to re wire the engine bay of the HT, are the following wire sizes correct.
Battery + and- lead 10mm2 wire
Alternator and ammeter 1mm2 wire
Gauge sensors and general wireing 0.75mm2 wire
Driving Lights 2 x 100W 1mm2 wire
Any dramas with these sizes.
ozchevy Offline
#2 Posted : Friday, 24 April 2009 9:20:42 AM(UTC)
ozchevy
Automotive cable is not the same as household cable in terms of the cross sectional sizing.
3mm multi stand single core is what is mostly used under the dash and to lighting circuits and alike.
Best you look here
http://media.narva.com.au/books/10.pd
basketcasebear Offline
#3 Posted : Friday, 24 April 2009 1:43:00 PM(UTC)
basketcasebear
hey bredbo.
i am not sure about the battery and alt wires,
but for most of my wiring i used 240vx15amp power lead, bunnings 15$ 25mtres with 3 wires, easy to strip,
far cheaper than auto wires, and takes more load than 12vx15>20amp auto wires, it i
DOH!!!
#4 Posted : Friday, 24 April 2009 7:41:31 PM(UTC)
1sqmm cable is only good for about 15A with air circulation. Whack it in an engine bay where its hot and un it with other loaded wires and it can only carry less. 200W of lamps is about 16A, so id be looking at something closer to 2.5sqmm. Ammeter and alt
Mr Void Offline
#5 Posted : Saturday, 25 April 2009 2:18:26 AM(UTC)
Mr Void
I was going to post something similar this morning - do you mean total wire diameter or sqmm Bredbo? Cause they are really thin wires.
For battery straps (starter and earths) I usually go 2awg (35sqmm or 12mm diam) but like HK1837 said 25sqmm is a gre
___________________
#6 Posted : Saturday, 25 April 2009 2:46:43 AM(UTC)
Itd only be V75 PVC so not really any good for engine bays.
#7 Posted : Saturday, 25 April 2009 3:41:18 AM(UTC)
basketcasebear
hey mr void,
i have no idea what the temp rating of the power lead cable is?
i do know it is alot thickerer than the thin overpriced auto cable.
i also know that 240vx15amp is alot more juice than 12vx15amp.
i havent used it for anything near heat, or
DOH!!!
#8 Posted : Saturday, 25 April 2009 3:51:26 AM(UTC)
Views messages in topic : 6,164
#9 Posted : Saturday, 25 April 2009 3:57:31 AM(UTC)
V105 PVC is OK, that is 0.6/1kV rated. Normal flexible cords are V75 PVC insulation and sheath. The maximum operating temperature of the insulation is 75degC which is normally from current flow in the cable but in an engine bay it is also external. The PV
#10 Posted : Saturday, 25 April 2009 4:12:35 AM(UTC)
basketcasebear
hey dok terry,
the copper in the power lead is alot thicker that the auto cable, and the covering is too,
and it appears to be alot more rubbery and flexible than the auto cable?
i know this does not mean it is more suitable, but from experience with p
DOH!!!
Mr Void Offline
#11 Posted : Saturday, 25 April 2009 4:15:24 AM(UTC)
Mr Void
Some real good information in this thread!
Such a refreshing change from the recent past with colby and co.!
___________________
Why are you reading this, you should be looking up there^^
Edited by user Saturday, 25 April 2009 4:16:13 AM(UTC)  | Reason: Not specified
___________________
ozchevy Offline
#12 Posted : Saturday, 25 April 2009 4:57:18 AM(UTC)
ozchevy
For places close to hot items like exhaust manifolds - I would personally use Silicon insulated cable. I use this alot at work for rebuilding Metal Halide lighting fixtures. Its three times more expensive though.
#13 Posted : Saturday, 25 April 2009 6:13:39 AM(UTC)
basketcasebear
i wonder what the power lead is rated at re heat??
it is far better insulated than house wiring.
it has to be pretty good cause of safety, being 240v??? aus standards etc
hhhmm?
bcb
it was but yesterday, i thought myself a fragment, quiveri
DOH!!!
kraul Offline
#14 Posted : Saturday, 25 April 2009 6:53:19 AM(UTC)
kraul
the insulation on ur normal flex leads that ur geting from bunnings isnt suitable to any of the enemys in a car, heat max 75degrees, oil, grease and fuel. wont take long for it to fail as the insulation will degrade. bad wiring generally means fire. iv se
#15 Posted : Saturday, 25 April 2009 7:35:17 AM(UTC)
basketcasebear
hey kraul,
what is the wire you buy for auto,s, temp rating?
where do you find the infomation on what the insulation is on power leads?
and what the infomation is on car wiring, re what the insulation is made of?
i would like to check it out.
i woul
DOH!!!
roy1126 Offline
#16 Posted : Saturday, 25 April 2009 7:36:19 AM(UTC)
roy1126
As a licensed sparky I have to agree with Kraul. There is no way I would use any of the cable I use everyday at work under the bonnet or anywhere else in my pride and joy. TPS (2 core and earth) cable will not last five minutes in a car subjected to any o
Mr Void Offline
#17 Posted : Saturday, 25 April 2009 7:46:51 AM(UTC)
Mr Void
roy1126 - can you post any info/tips about where to get auto wire at a good price? Are there any places around - supercheap/autobarn etc dont always have the best deals around...?
___________________
___________________
#18 Posted : Saturday, 25 April 2009 7:52:57 AM(UTC)
basketcasebear
hey roy,
house wiring is low quality, but power leads are not.
where do we find out what power leads are made of??
or what grade of plastic it is?
how does anyone know whether it is exactly the same material?? or not, as car wiring.
gee i dont know,
DOH!!!
Mr Void Offline
#19 Posted : Saturday, 25 April 2009 7:58:45 AM(UTC)
Mr Void
Haha bcb - that brain of your just never stops ticking does it!!?? ; p
___________________
___________________
#20 Posted : Saturday, 25 April 2009 10:59:50 AM(UTC)
basketcasebear
well thats so true, mr void.
but then again, in our increasingly scam insaturated world, it would not surprise me in the least, if we found out that the motor wire is the same as powerlead wire??
i read a little on it,, and it seems it is all pvc, and
DOH!!!
Guest (13)
