HQforme Offline
#1 Posted : Saturday, 25 April 2009 10:22:36 AM(UTC)
HQforme
Id been getting oil in my intake manifold for a while now, since my last rebuild, through the PCV. Was putting oil in every week while i chased answers. Long story short i tried everything you could ever think of to solve the problem: PCV valves, locations, hoses, diameters, checking for blow by, different breather caps etc etc.
And you know what it was? My rocker cover. Something i think Dr Terry touched on while i was looking for help. Apparently Rare Spares have never heard such a thing, which is fair enough, but here's the proof. 1 worked 202, 1 aftermarket chrome rocker cover, PCV sucks oil. Put the old cover on with two gaskets to clear the roller rockers, and we're away!
Wonder if this happened to anyone else? Those rocker covers sell by the dozens.
"Silly modern cars"
#2 Posted : Saturday, 25 April 2009 8:27:15 PM(UTC)
Probably the lack of baffles in the aftermaket cover.
cheezel308 Offline
#3 Posted : Saturday, 25 April 2009 8:54:48 PM(UTC)
cheezel308
i have one of them aftermarket finned holden rocker cover im having the same sort of problems,im running a T piece PVC to booster and manifold......
im thinking of canning the T piece and PVC and running a hose straight from booster to manifold then from
HQforme Offline
#4 Posted : Saturday, 25 April 2009 9:48:10 PM(UTC)
HQforme
Oh, there was baffling, under the fller cap as well (total pain to fill up) but the baffle under the PCV was just a thin channel, about an inch thick at most. Stock covers have a plate that runs along half the cover, so theres a huge difference, so yeah,
"Silly modern cars"
#5 Posted : Sunday, 26 April 2009 12:32:44 AM(UTC)
cheezel308 Offline
#6 Posted : Sunday, 26 April 2009 1:00:39 AM(UTC)
cheezel308
terry
no its a 202 in an lj..........where do i get this split system you speak of!?!
#7 Posted : Sunday, 26 April 2009 1:23:40 AM(UTC)
Sorry, I confused you with another guy.
To run a PCV valve with an X2 manifold, you need to remove the manifold & drill & tap the manifold in two places on its inner face. You cant drill the outer face, thats the water jacket, you cant drill the top or
cheezel308 Offline
#8 Posted : Sunday, 26 April 2009 1:45:52 AM(UTC)
cheezel308
its a stinking 202 with a 4 barrel carb and big hi-flow redline manifold.
Mr Void Offline
#9 Posted : Sunday, 26 April 2009 6:47:53 AM(UTC)
Mr Void
hehe then why the hell are you called cheezel308!!!!! Thats just plain confusing (even without the red I had with...and after dinner!) ; )
___________________
Why are you reading this, you should be looking up there^^
- HJ turbotonner looks
___________________
HQforme Offline
#10 Posted : Sunday, 26 April 2009 9:02:54 AM(UTC)
HQforme
Dr Terry, that was me with the glazing! Id t-pieced the PCV temporarily with the brake booster and it meant that all the oil sucked up was deposited straight into 5 and 6. That combined with what seems to be a power valve problem (apparently they need to
"Silly modern cars"
#11 Posted : Sunday, 26 April 2009 5:22:19 PM(UTC)
Hi HQforme.
How do you space carburettors downwards, to be ultra low ?? Where did you drill to fit the one single central PCV port ??
HQforme Offline
#12 Posted : Sunday, 26 April 2009 9:38:44 PM(UTC)
HQforme
More accurately i should have said that i made the thinnest spacer possible so that the lowest point on the throttle linkages and choke rod (linking choke plate to throttle) barely clears the manifold (about 1mm max). Any taller and the filters would foul
"Silly modern cars"
cheezel308 Offline
#13 Posted : Monday, 27 April 2009 7:00:39 AM(UTC)
cheezel308
im still not sure what a PCV valve even does!?!
Guest (13)
