hkdave Offline
#1 Posted : Thursday, 30 April 2009 1:48:41 AM(UTC)
hkdave
Does anybody know where i can buy seat belt bolts/washers/mounting plates from in Brisbane? Im hoping i can buy a kit, as i have seen them on the U.S. sites.
HkDave
Jvanner Offline
#2 Posted : Thursday, 30 April 2009 4:30:37 AM(UTC)
Jvanner
most engineers will tell you what they want from a mounting plate and most wrecker will have the bolts you need
80569K Offline
#3 Posted : Thursday, 30 April 2009 5:30:20 AM(UTC)
80569K
"most wrecker will have the bolts you need"
Maybe not.
If its for up to HK-T then you will need 7/16" UNF bolts which are not that easy to find, I might be wrong here but I think that sometime around 1970 seat belt bolts were changed to 7/16" UNC.
#4 Posted : Friday, 1 May 2009 4:02:02 AM(UTC)
To my knowledge most seat belt bolts in the aussie cars were always 7/16 unf and still are , as i recently had some Nasco Accessory HK Rear Parcel shelf Seat belt Mounting plates made up , and the special resistence welded "weld" nuts which i could not ge
#5 Posted : Friday, 1 May 2009 5:17:56 AM(UTC)
new cars using 7/16th bolts? why would they use unf bolts in a metric car, when they have been metric for along time?
im not saying they dont use them, just that it seams strange that they would
#6 Posted : Friday, 1 May 2009 7:32:09 AM(UTC)
Thats what i thought,but thats what they said to me , as otherwise they would have rejected making them for me. I may pull one out of my commodore tomorrow and check it out ?
www.monaromuscleparts.com
petaus Offline
#7 Posted : Friday, 1 May 2009 7:38:54 AM(UTC)
petaus
i think they still are 7\16 unf, fords still use 1/2 inch unf for the wheel stud,s i remeber commodores like vn extra on the engine one bolt was metric the next thing was imperial a real pain in the ass,
so while now most things are metric every now and
HZute-efi-VS5L Offline
#8 Posted : Friday, 1 May 2009 8:47:58 AM(UTC)
HZute-efi-VS5L
vl onwards use a M14 fine bolt from memory. maybe even M16.
jason
www.stickthisdecals.com.au
80569K Offline
#9 Posted : Saturday, 2 May 2009 6:01:19 AM(UTC)
80569K
Monaro Muscle Parts. I bought a pair of your plates for my HK and can highly recommend them.
I visited a wrecker recently and pulled a full set of belts out of a HJ sedan and the bolts were coarse threaded.
I thought Id read somewhere on th
hkdave Offline
#10 Posted : Sunday, 3 May 2009 7:10:29 AM(UTC)
hkdave
Thanks guys, but i do need the backing plate/big washer as the back of the car doesnt have threaded holes.
HkDave
MrPink Offline
#11 Posted : Monday, 4 May 2009 5:54:02 AM(UTC)
MrPink
He has them with the weld nut on the plate, read the other replies.
Guest (11)
