#1 Posted : Friday, 1 May 2009 7:02:17 AM(UTC)
VT 5.7 crank into a blue 308? does it fit ?.or..what 5.7 crank(GMH only)does if any?(after clearancing the block)
Jim in adelaide
adam PERTH Offline
#2 Posted : Friday, 1 May 2009 8:01:08 AM(UTC)
adam PERTH
i think only after VR block up.
WANTED:
-HZ GTS steering wheel, buckskin.
-2 x 15 x 8 Dragway centrelines
#3 Posted : Friday, 1 May 2009 8:05:51 AM(UTC)
Adam i reckon your right!
Jim in adelaide
#4 Posted : Friday, 1 May 2009 6:43:57 PM(UTC)
Itll fit, youll just have to clearance the bottoms of the bore like in a late VR onwards block (or like you do for any other 350 stroker crank into pre mid-VR 304/308 block).
Being a blue block itll have a rope seal so all will be OK. Itll end up at 350c
#5 Posted : Saturday, 2 May 2009 4:02:01 AM(UTC)
Thanxz all for your help , got paint today(satin mist metalic) going onto the body straightening.
Jim in adelaide
Edited by user Saturday, 2 May 2009 4:03:20 AM(UTC)  | Reason: Not specified
