Fastlane
Holden Forums
Holden General Discussion
VT 5.7 crank into a blue 308? does it fit ?.or..
VT 5.7 crank into a blue 308? does it fit ?.or..what 5.7 crank(GMH only)does if any?(after clearancing the block)
Jim in adelaide |
Jim in Adelaide.. |
i think only after VR block up.
WANTED: -HZ GTS steering wheel, buckskin. -2 x 15 x 8 Dragway centrelines |
Adam i reckon your right!
Jim in adelaide |
Jim in Adelaide.. |
Thanks: 1 times Was thanked: 615 time(s) in 582 post(s)
Itll fit, youll just have to clearance the bottoms of the bore like in a late VR onwards block (or like you do for any other 350 stroker crank into pre mid-VR 304/308 block). Being a blue block itll have a rope seal so all will be OK. Itll end up at 350c |
Thanxz all for your help , got paint today(satin mist metalic) going onto the body straightening. Jim in adelaide Edited by user Saturday, 2 May 2009 4:03:20 AM(UTC)
| Reason: Not specified |
Jim in Adelaide.. |
Fastlane
Holden Forums
