AdsRuss Offline
#1 Posted : Wednesday, 16 September 2009 11:03:00 PM(UTC)
AdsRuss
I am looking at a 96 EL? Falcon.
Can anyone please tell me where to find the engine number so I can do a REVS check?
AdsRuss Offline
#2 Posted : Friday, 18 September 2009 6:53:56 PM(UTC)
AdsRuss
Anyone????
#3 Posted : Tuesday, 22 September 2009 11:21:17 PM(UTC)
Yes it's on the block sort of directly behind the water pump. Stand next to the drivers side front wheel and point the torch down between the back of the power steering pump and sort of in front of the exhaust manifold and it will be there.
If
AdsRuss Offline
#4 Posted : Wednesday, 23 September 2009 11:37:50 PM(UTC)
AdsRuss
Thanks for your help. Will check it out.
#5 Posted : Wednesday, 23 September 2009 11:59:12 PM(UTC)
Oh ant the number is stamped onto the block casting NOT a machined area.
If at first you don't succeed then skydiving is not for you.
