clevland351 Offline
#1 Posted : Thursday, 28 January 2010 11:01:37 PM(UTC)
clevland351
Has any one has experience in fitting aftermarket straight cut timing gears under the cover of an Aussie 302 C . Seems like the method of sandwiching the idler gears between the block a cover is a bit hit and miss. Thinking that may be I should just run a good twin row chain and not bother with the gear set up
AR
AR
russxr67 Offline
#2 Posted : Friday, 29 January 2010 7:13:21 AM(UTC)
russxr67
sounds like a good idea. The only decent gear drive is the Milodon unit.
Docktor Offline
#3 Posted : Friday, 29 January 2010 11:30:36 AM(UTC)
Docktor
thats the way they go in mate, pper and lower then drop the idler gears in, Done quite a few. tho i still prefer a double row chain on my stock cars
Paul351xb Offline
#4 Posted : Sunday, 31 January 2010 4:39:53 AM(UTC)
Paul351xb
For the street, double row chain. Just my 2 cents.
"Life, a series of events, woven into a tapestry which becomes our destiny"
Colesy Offline
#5 Posted : Sunday, 31 January 2010 6:02:42 PM(UTC)
Colesy
Nothing beats the whine of gear drives. Ok a supercharger
Paul351xb Offline
#6 Posted : Monday, 1 February 2010 2:09:13 AM(UTC)
Paul351xb
At first. After a while they just start annoying you and everyone else in the vicinity. Especially if it's a daily driver.
