stkilda.1 Offline
#1 Posted : Saturday, 5 September 2015 9:19:11 PM(UTC)
stkilda.1
Hi all just wondering before I start digging in, my 253 was running but I left it alone for a while now I changed spark plugs and oil oil filter, the ignition lights come on but nothing is happening , no start where do I start looking.
castellan Offline
#2 Posted : Saturday, 5 September 2015 10:11:06 PM(UTC)
castellan
No start ? starter motor not winging over ?
If the engine will not fire up what have you done ? pulled the lead of the coil or dizzy ?
Did you take of the dizzy cap, touch anything ? pulled the rotter button off and not put it back on.
Are all the wires on the coil, like you have not broken oneEh?
stkilda.1 Offline
#3 Posted : Sunday, 6 September 2015 3:51:58 PM(UTC)
stkilda.1
ok found the problem, before doing the main work like taking out the starter motor, I checked all fuses and cleaned wiring connections, then I noticed a wiring plug was disconnected under the dash board, once I plugged it back in it started straight away and runs great, now off to the panel shop full paint job, thanks for your help.
