Simmo Offline
#1 Posted : Thursday, 15 October 2015 10:11:39 AM(UTC)
Simmo
Looking to remove a TH400 and fit a TKO600 into a HK coupe.
Has anyone done this, it looks like it should fit, how does the mount line up with existing cross member. Shifter position in relation to console?
Car was originally a manual so I can easily refit a clutch pedal.
#2 Posted : Thursday, 15 October 2015 6:23:38 PM(UTC)
You'll probably have to butcher the main floor crossmember (which supports the seats). A Muncie will fit better if you haven't yet bought a box.
Simmo Offline
#3 Posted : Friday, 16 October 2015 9:24:09 AM(UTC)
Simmo
Ive had a Muncie and TH400 in there in the past and still have a spare M21, but Im after an overdrive and I need the strength of the tremec to survive a big motor on boost.
#4 Posted : Friday, 16 October 2015 10:08:26 AM(UTC)
Do some measuring but you may have to get it Engineered as I think even a Toploader sees the need for butchering of that main floor member that supports the front of the seats.
