Jeffro81 Offline
#1 Posted : Saturday, 17 October 2015 7:38:49 AM(UTC)
Jeffro81
Hi guys.
Got the seats of my HK out, began pulling out crumbling vinyl floor to repair rust. The rear floor section was wet as. The car has been in storage for 8-9 months, at least. I thought it would have dried. The under lay material was wet long enough to the point it was black from rot. There was newspaper stuck to the floor. As I was cleaning it up, there were a number of punched holes in the floor, bit smaller then the size of a 1c coin which I assume were drainage holes. Thing is there was black adhesive/sealant blocking most of them up.
Question time. I assume their drainage holes? What are the upside down ashtray looking plugs screwed in? I spoke to someone and they weren't sure. They thought the black stuff was from when the floor was put in. Thing is this black stuff covers most of the holes. I thought they would have been careful enough to not allow flooring adhesive to fill drainage holes.
Thoughts on which way to go forward.
Thanks, Jeff
#2 Posted : Saturday, 17 October 2015 9:12:06 AM(UTC)
Holes were punched at low points when they were bodies in white, so they could be put outside and water would drain out. At least Pagewood did this. Holes were filled with body sealer in the painting/sealing process.
Edited by user Saturday, 17 October 2015 9:13:58 AM(UTC)  | Reason: Not specified
gm5735 Offline
#3 Posted : Saturday, 17 October 2015 10:34:20 AM(UTC)
gm5735
Sure it was newspaper? Not a build sheet by any chance?
The Dandenong bodies were the same. I've even found little sheetmetal offcuts embedded in the sealer in the 3/8" holes, in fact so often I think it was deliberate. Watch out for that Elastite sealer - it's full of asbestos.
The small holes were drains for use during the manufacturing process, as Byron said. The larger holes covered by a "top hat" plug fixed with self tapping screws, so they could be easily removed to drain the floor should you attempt to ford a river, or drive the car into a lake.
These days the entire car would be written off by the insurance companies if it got wet above the sills.
Byron, what do you mean by "bodies in white"?
#4 Posted : Saturday, 17 October 2015 11:13:16 AM(UTC)
Body in white is the completed sheetmetal body prior to the paint process.
Jeffro81 Offline
#5 Posted : Saturday, 17 October 2015 12:10:09 PM(UTC)
Jeffro81
Cool, thanks for the replies.
So HK1837 with the holes, leave them as is or fill them in? I don't want to have a wet floor issue in the future like I've just come across. It looked nasty and would have rusted the hell out of the floor. Fill with adhesive or MIG?
gm5735, yeah newspaper. when it was stuck to the floor I could read the writing. It had vinyl, heshen type material underneath this and then newspaper. But it was black with rot in most places and the drivers side had a rust hole I could put my fist through. Thanks about the black elastite. I have been chipping off with a screwdriver/scrapper as I've been warned about it. Don't sand it asbestos material. Regardless, I wear a good dust mask when I sand.
#6 Posted : Saturday, 17 October 2015 4:37:16 PM(UTC)
Just fill them up with black goo eg body deadener, Sikaflex etc.
Jeffro81 Offline
#7 Posted : Sunday, 18 October 2015 11:08:59 AM(UTC)
Jeffro81
thanks
Jeffro81 Offline
#8 Posted : Sunday, 18 October 2015 11:09:51 AM(UTC)
Jeffro81
Thanks for the help. Much appreciated.
Guest (5)
