Matty Q Offline
#1 Posted : Monday, 26 October 2015 5:53:05 PM(UTC)
Matty Q
'evening all
The HJ Caprice protect trundles along. Back from sandblaster and making progress.
I have a question specific to the side protector strips running the length of the car (about half way down the doors / fenders). I need to sort this out now, as it will affect if I do any more body fabrication (filling of rivet / clip holes) etc. before I continue with body prep / painting.
When I purchased it, it had what I was told is the later HX or HZ strip fitted (not original). This is a chrome strip about 30mm wide, with a black rubber insert around 10mm wide rinning down the middle of it (slightly off centre).
I'm seeking several things:
1. What was the original strip fitted to this, including width, style and colour (the car's original colour is a dark metallic brown)
2. How was this held on? The stud-rivet/clip style (similar to that used to hold the windscreen chrome trim on), or holes / clips? My car seems to have both holes down the side, and the stud-rivets, but I suspect this is a result of the retrofitting of the non-original strip.
3. Does anyone know where I can get the right strip? (I'm based in Melbourne, but can freight from anywhere in Australia.)
Thanks in advance
Matt
Continually amazing how people are willing to share information.
#2 Posted : Monday, 26 October 2015 6:24:13 PM(UTC)
HJ-HX normally (not certain if Caprice is the same) use holes on the ends of the strips and studs in between. The ends have a screw from behind. From memory it is the ends of the doors and the front of the guards that have holes. The rear of the quarter may as well.
Matty Q Offline
#3 Posted : Friday, 6 November 2015 4:57:20 PM(UTC)
Matty Q
Thanks for that. My seems to have a combination.
