Gerard Offline
#1 Posted : Saturday, 12 December 2015 9:43:55 PM(UTC)
Gerard
What is the recommended sealant when installing the wiper arm pivots? I have windscreen sealant and was planning to use it on the pivot install. Noted that the original sealant was more of a grey mastic/putty type of sealer. Is there a better sealant for this than the windscreen sealant, which can also be used in other areas on the body where a sealant is required e.g. installing tail lights, the stainless steel mouldings that hold the side window rubber system on the Monaro or other areas.
Gerard
This page was generated in 0.080 seconds.
