Joined: 12/12/2015(UTC) Posts: 3 ![Australia Australia]() Location: Perth Thanks: 1 times
I was hoping that someone could help me out with the colour and trim style for my 1965 EH Panel Van.
The Id is as follows:
Body: EH2104M-S10-2604A Trim: 900-C54 Paint: 568-0046 Insert: Top:
Additional Id below: P007346
As far as I am aware it was owned by the Post Master General service (Australia Post).
Regards,
Trevor
Yes, it sounds like an ex-PMG EH van.
568-0046 is the Dulux code for Mercury Red, which was the red used on PMG vehicles in that era.
900 = Mercury Red all over (single tone) C54 = Elephant Grey interior trim
EH2104M = EH panel van with manual trans S10 = Govt, equipment package 2604A = 2604th EH van to be built in Adelaide
The 'additional ID' mentioned is the tag number, fitted at the assembly plant. In this case P = Perth
The chassis number, stamped on the RH inner guard, should also have a P suffix.
Dr Terry |
 2 users thanked Dr Terry for this useful post.
Thanks Dr Terry for that information, it is very helpful. Do you know if the seat, door trim, and headlining were all the same colour? When I purchased the car, the headlining was the off-white/possibly light grey colour in a brick pattern (I think this was original); the seat was in poor condition with ripped cloth; and the trims were a dark red with stitching (so most likely not the original). Do you know what the pattern styling for the seat and door trim would be? I noted some upholsterers mention their styles of C36, C35 etc but i can't find the style for C54. I also note a previous thread that you responded to, which was in regards to a PMG Ute. this had an elephant grey interior. Is it likely that the styling from that vehicle would have been the same? http://www.fastlane.com....tst30049_EH-Ute-PMG.aspx Would the seat have been vinyl or cloth? Trevor
The headlining sounds to be correct & originally it was an off-white.
There were no cloth seat coverings in EH. All except Premier were in 'elascofab' vinyl, while Premiers were in leather.
The patterning style of the seat & door trim for utes, vans & standard sedans & wagons were all the same, only the colour differed.
They were either Bolero Red, Columbine Blue, Triton Green, Palais Green or Elephant Grey & all in single tone.
Specials had 7 different trim colours, but theirs were in two-tone.
Dr Terry |
Thanks will help in finalising my car.
Trevor
