basketcasebear Offline
#1 Posted : Tuesday, 27 May 2008 5:13:39 AM(UTC)
basketcasebear
hey yall,
I am looking for the lightest scissor jack with the most travell..?
i have looked at a couple, i have one that is off a toyota, but it only travells about 300mm
I am looking for at least 400 mm travell?
i also have a mercedes one, that travells far enough, but it is too hard to fit a windscreen wiper motor to it.
i wonder whether a gemini one travells furtherer?
there are no wreckers around here,
so i am hoping some one in here will save me alot of driving around?
thanks youall
bcb
ptpro
some men see things as they are, and ask "why"
I dream of things that never were, and say, "bloody ripper idea mate, lets try it",!!
DOH!!!
80737k Offline
#2 Posted : Tuesday, 27 May 2008 5:32:25 AM(UTC)
80737k
Ive got a couple of scissor jacks in the shed i could measure tomorrow for you but i dunno what theyre out of, prolly commodore but im far from certain so i guess knowing how high they lift would be of no real help ? I will check see if they have (hopeful
Fossil fuels are YUMMY !
80737k Offline
#3 Posted : Tuesday, 27 May 2008 5:32:25 AM(UTC)
80737k
I've got a couple of scissor jacks in the shed i could measure tomorrow for you but i dunno what they're out of, prolly commodore but i'm far from certain so i guess knowing how high they lift would be of no real help ? I will check see if they have (hope
#4 Posted : Tuesday, 27 May 2008 6:05:43 AM(UTC)
I once knew a guy who knew jack ****t, he was a mate of sum kuntt !
Any small 4wd`s use sissor jacks ? they have a bit of height.
#5 Posted : Tuesday, 27 May 2008 6:12:30 AM(UTC)
basketcasebear
thanks cloudy 807k umm it is not for jacking up a car! so matters not what they are off!! 4wd,s uummm sounds maybe like the go? cause they would have to lift higher in most cases?
will ringa around tomoro.. see what becomes of it.
i dont know jack sh
DOH!!!
80737k Offline
#6 Posted : Tuesday, 27 May 2008 6:59:33 AM(UTC)
80737k
#7 Posted : Tuesday, 27 May 2008 7:30:52 AM(UTC)
You are a member of these groups:: Guests
yes thats true 807k i put my cordless onto this toyota jack, and it lifted the roof easy, so brainwave here figured, that if i can get two jacks, one either side, then two windscreen wiper motors should be strong enough, to lift roof??
hopefully they
80737k Offline
#8 Posted : Tuesday, 27 May 2008 7:39:40 AM(UTC)
80737k
I like the sound of ya wiper motor idea but you'd have to try them to see if strong enough. If you use identical wipers wired into the one switch, i dunno why they wouldn't lift at the same rate. If they did, some electrical genius could prolly sort it us
80737k Offline
#9 Posted : Tuesday, 27 May 2008 7:39:40 AM(UTC)
80737k
I like the sound of ya wiper motor idea but youd have to try them to see if strong enough. If you use identical wipers wired into the one switch, i dunno why they wouldnt lift at the same rate. If they did, some electrical genius could prolly sort it usin
#10 Posted : Tuesday, 27 May 2008 7:51:39 AM(UTC)
well 807k
the 12v cordless was strong enough,, so the wiper motors are geared even lower, and have bigger motors in them!
so will a bit of luck, they will do the job
bcb
#11 Posted : Tuesday, 27 May 2008 4:15:30 PM(UTC)
what about using the `X` lifters from a pop-top caravan, i replaced mine cost about $80.ea and are held in by 4x screws and are spring loaded.
#12 Posted : Wednesday, 28 May 2008 3:39:27 AM(UTC)
basketcasebear
hhhmm?? cloudy, might have too look at them, cause although my poptop floor, roof racks, lift up and forward,,maybe i better just bite the bullet and have it lift straight up??
how high do they lift cloudy? and how strong are they?
bcb
ptpro
DOH!!!
Fred Offline
#13 Posted : Thursday, 29 May 2008 5:52:09 PM(UTC)
Fred
The original Toyota ones are perfect.
#14 Posted : Friday, 30 May 2008 3:48:52 AM(UTC)
basketcasebear
hmm?
the toyota one I have fred, is a double scissor one?
it is very compact, and well designed, but only travells 300mm
but thanks for that will look arounf for earlier ones, even if i dont use them for the pop top, i will use then for stabilizers, el
DOH!!!
#15 Posted : Saturday, 31 May 2008 7:11:41 PM(UTC)
there full extenion can be about 800mm but they will only open to the height of your canvas /vynil area what ever that height is, they will hold about 40kg each, a pair of handles mounted under your roof on the interior will pull them down, spring loaded
#16 Posted : Saturday, 31 May 2008 7:57:43 PM(UTC)
BCB - the other way could be to mount one jack on top of the other for a double scissor arrangement - so although the colsed height may end up being 100mm instead of 50mm, youll end up with 600mm lift.
_________________________________
#17 Posted : Saturday, 31 May 2008 7:57:43 PM(UTC)
BCB - the other way could be to mount one jack on top of the other for a 'double scissor' arrangement - so although the colsed height may end up being 100mm instead of 50mm, you'll end up with 600mm lift.
#18 Posted : Sunday, 1 June 2008 2:12:28 AM(UTC)
basketcasebear
hey comnut,
thats a thought 2 together, but height is a prob,
I am going to get 2 tubes tomoro, and a small compressor, and see if i can use the air to lift them?
this oughta be interesting??
will let u know hooowww ii gooo!
bcb
ptpro
som
DOH!!!
This page was generated in 0.117 seconds.
