fitzsi Offline
#1 Posted : Monday, 4 January 2016 10:34:52 PM(UTC)
fitzsi
Does anyone know what it costs to replace an air conditioning clutch on a v6 VZ commodore as mine is shot
#2 Posted : Tuesday, 5 January 2016 6:49:09 AM(UTC)
Hi fitzsi.
The clutch is made up of various separate items, it very much depends on which part is 'shot' & what the problem is or what caused it.
The 3 main parts are the clutch hub (the flat front plate), the pulley & bearing (the bit that the belt sits on) & the magnetic clutch coil (the electrical bit which pulls in the clutch hub).
If the coil is open circuit, that an easy one. A new coil is around $180-$200, but the other 2 pieces need to be removed to fit it.
If either of the other 2 are crook, there maybe other dramas, so it's usually prudent to replace the whole compressor ($600-$650) rather than waste money replacing items bit by bit, in search of the original problem.
A good clean 2nd compressor is another option. Just get a pro to check it out & get it re-oiled, before fitting & gassing.
