oldmanmonaro Offline
#1 Posted : Sunday, 17 January 2016 10:42:29 PM(UTC)
oldmanmonaro
Gday to all, Does anyone know where in Melbourne, I can get replacement engine pipes (dual system) from the cast iron manifolds to the mufflers on a 350 HQ? My mufflers and tail pipes are good so I want to reuse them but I need the engine pipes with the cross over connection. I was hoping to buy replacement pipes that I could fit at home as i can't drive the car to an exhaust shop at present. In the past you could buy replacement pipes bent up to original factory specifications but I cannot find anyone who does this now. Cheers Mike
detective Offline
#2 Posted : Monday, 18 January 2016 6:57:45 PM(UTC)
detective
...with their up and down outlets (with the heat riser in the RH manifold) I know they are a fairly complex shaped pair of pipes...with crossover
...A sample copy is always ideal, but failing that a request to an old reputable exhaust company may produce the drawing or "map" for what you require.
...Is she a Statesman or Monaro ?...just for interests sake ...Cheers
