YetAnotherForum.NET Help
9 Pages<12345>»
gm5735 Offline
#41 Posted : Thursday, 11 February 2016 5:52:36 PM(UTC)
gm5735
Quote:
Yes we did, Australian Super fuel was around 97-98 Octane, US was higher for Premium but our Standard fuel was lower than US Regular, hence the engines we got here that were designed for US Regular had to run on Super, hence why GMH gave the engines more advance.
You beat me to it.
In Australia the old leaded "Super" was 98 octane, rated in RON, and measured by a standard ASTM test engine. RON is still used in Australia today, with additional specified measurements.
The old Australian "Standard" was 92 Octane RON, also measured the same way.
Up until 1971 petrol in the US was advertised by RON, and the pumps were marked with RON Octane rating, the same as was done here.
There were many different octane ratings available in the US, up to Sunoco 260 which was 102 Octane, RON. US Regular was 91 Octane RON.
Some pumps even had a blend adjustment so you could choose different octane ratings.
In 1971 the US Federal Government mandated suppliers to use the average of RON and MON marked on the pumps. This is the R+M/2 symbol.
MON is a different measurement method, and yields a lower number than RON.
Holden required the use of "Super" for engines of higher than 8.5:1 compression.
Most of the US engines (over 8.5:1 compression) we got here could stand more advance than in the US due to better fuel, hence the distributor changes and more advance and, as you've noted before, should yield more power.
castellan Offline
#42 Posted : Thursday, 11 February 2016 6:42:01 PM(UTC)
castellan
SAE set a standard of 0.004 lift for the cam figures so Holden may be that without the ramps, I have heard of 0.002 ?
Most cam company used 0.006 in the days before the modern way of 0.050 now used.
7434871 cam is used in the HT, HG, HQ 308 and the 253, but the 253 is retarded -5 degrees as was the LH Torana 308
using the cam gear PN 7434699. the other cam gear is PN 2808386 and this is zero deg.
2825882 is a HJ to VL 308 cam it has one ring cast on it to ID it, it's timing gear PN 7434699 = - 5 deg and is in 28/72 = 280 duration with ex 78/30 = 288 dur and if you use the PN 2808386 timing gear you will improve power with this cam.
The HJ to VH 253 cam is 92000944 but the cam gear PN is 7434699 on HJ to HZ but the VB to VH has PN 9936255.
So I have some other Holden PN cams
92029026 = VK HDT-SS
92060099 = VL SS GROUP A
92061392 = VN to VS
92063314 = VT
92063624 = VT 195KW and the 5.7L 215KW
#43 Posted : Thursday, 11 February 2016 7:03:35 PM(UTC)
92061392 = VN to VS
92063314 = VT
You'll find HJ 253 is the same cam as HT-HQ, the engine didn't change at all. It was the trial ADR27A HJ's that used the HX pollution cam. GMH changed the pollution 4.2 during HZ and at this time it also revised the rear axle ratio for the 4.2, it'll be at that time the revised pollution 253 cam was used. Probably in line with VB engines.
castellan Offline
#44 Posted : Thursday, 11 February 2016 8:03:31 PM(UTC)
castellan
ADR27 stuff came in in September 1972 but Ford and Chrysler got an exemption until I think 1/73. Will confirm later.
ADR27 didn't affect performance, just idle mixture.
HJ 5.0L is more powerful, there is no argument, they simply are.
Gross hp figures are the ONLY reliable source of comparison, net is rubbish.
GMH had a habit of disguising the performance of their top spec manual cars. They did it for HK, HT, HG, HQ and even HJ. Some cars got reported correctly but most that were allowed out to the press were hobbled. Try and find a road test for an LH SLR5000 with a HJ engine, even an early LX. These were quicker over the 1/4 and higher trap speed than an L34. Rob Luck did a road test on a private GTS327, Mel Nichols got a properly tuned HT GTS350 and later Robbo did too. HQ GT350 manual was never properly tested in real tune, only the auto was, reporters even stated that they were scratching their heads why the auto was over 3 seconds faster 0-100mph. Even the press test HJ 5.0L manual HJ GTS was fiddled with. The only place you'll find the true performance figures on a manual HT-HG GTS350 was on the unopened HG in AMC a few years back - the car had never even had a clutch change until a few years after the article.
In the end you need to ignore the 1/4 mile tests but look at the trap speed at the end of the quarter. This will give you the true performance potential as it takes out wheelspin. If you can see if you can find Rob Luck's road test on the HK GTS327, compare its mph at the end of the 1/4 to what AMC got for the HG GTS350 and original tests of the Phase II and III. You can see the slight increases in mph between them. All interesting stuff.
Sep 1973 the Falcons lost the 351 4V heads and lost the open oil breathers and got the PCV system as did the HQ in Sep 1973.
How, or may I say why do Holden use ECE power figures now and why did they use DIN from 1978 in the VB, over the old Gross HP figures, are they backwards in doing so ? should they go back to Gross HP figures.
If I were into testing cars I would not print the test if the car was a bad example, it's just bad business ethics, that no one should stupe too.
There is the case of the same engines that perform well and the ones that don't out of a model as well, that one can deal with as well.
The HJ 308 having the extra compression this works out too more power in SAE gross figures as the power goes up because that's how they work out the power and that's why the 250 HP rating and nothing other than that.
Look at the other Holden engines and do the maths with low comp engines and high, bang that it, that's all it is to it.
Falcon GT with 4V heads had a compression rating of 11:1 and the GT=HO PH2 and PH3 has the same rating, or may we say that is the figure reported ? so that's where the power figures come from, they are rated the same as the GT and they could get away with it as such, but they could not get away with it if the rating was in Net or SAE or ECE HP figures.
Look at it this way, I have a 202 red engine say, stock as a rock, now I am going to put a 173 head on it, and here we have more power according to SAE Gross HP figures, we have just jumped from 9.4:1 to about 10.5:1 I think it is, now what if we go down to 7.8 ?
Here is a HX-Z 3.3L manual high comp is rated at 81KW and the low comp is 76KW.Gross
Here is a VB 3.3L manual high comp is rated at 64KW and the low comp is 55KW.DIN
They are the same engines.
We can see that the twin exhaust makes more power on the 253 and 308 from the VB commodore on.
So with a HT to HJ 253 we have a rating of 185HP Gross, now we know the HJ 253 has a smaller cam for sure so it must not have the same power ? and if we have the std exhaust or the N10 holden twin exhaust the power must increase for sure but with SAE Gross it does not take account of such a thing and when we look at the 307 Chev and the 327's and 350's and try to work it all out it can get all a bit out of hand to the facts.
No factory Holden with a 307 engine out performed a 308, just like the Falcon 302 V8 could not out perform a 308 up to a XB that's for sure and there is a good reason why it is so. Think Maybe a XT GT could.
Yes, 9/73 for GMH too I made a mistake in the prior post with 9/72. 9/73 is when GMH introduced all their new clean air engines (with the sticker on the sunvisor) except for the delayed batch of the final XU1's (delayed due to the special engine I believe). However Ford and/or Chrysler weren't ready and ADR27 didn't become mandatory until after 3/74 (when HQ's chassis prefix went from DHQ to EHQ).
Gross hp is the only way you can compare engines, once they are quoted net it becomes a dog's breakfast for engine comparison purposes. Gross is a level playing field with no accessories which in themselves can create large variations. Net is better for vehicle comparison. I think it became mandated, happened in the USA in 1972 and a few years later here.
Correct, HJ 308 had more power, it was due to a compression increase. This is basic engine 101. It was a far superior performing and powerful engine than the HT-HQ engine, so much so it saw the death of the imported 400ci SBC engine in HJ and the requirement of the TH transmission.
Those Ford figures are smoke and mirrors, but you can play that game with any hp figures you like. GMH did it with L34, 1973 XU1 plus they never changed the published hp figures for the McKinnon GTS327 engines (240hp real, earlier were 250hp) of the final HG GTS350 engines. GM did it with the LM1 engine and the ZL1 plus others. We are talking advertised hp here, not real gross hp.
Power changes with compression, and net figures will be lower than gross, again engine 101.
That is right, gross is in a controlled environment, engine has exhaust headers but no exhaust. The gross figures make it easier to compare the engines, takes the accessories and exhaust out of the equation. Net allows you to compare the actual cars, but as to comparing engines gross is the go.
Correct, a stock 307 HK-HG has less power than a stock HT 308. Put N10 dual exhaust on either and you would get similar gains in installed hp on both. However the comparison is unfair as the 308 got a far superior carby and higher compression. On a 327 the Quadrajet was worth 10hp alone on the 1967 engine over the earlier 1966 4BBL (230hp vs 240hp). The 2BBL 327 from 1967 was 210hp and the 4BBL was exactly the same engine other than for the Quadrajet and manifold to suit and it was 240hp. The 1968 307 was 200hp (GMH gave it 210hp but our 307 got more advance and was rated for super fuel), so give it the 4BBL carb/manifold and you'd probably see it just about equal with the 308 in performance if both have the same style exhaust fitted. XT would probably be quicker than a HT-HG 308. HQ is lighter. I doubt an XT would outperform a a HJ 308 though.
Edit - I missed the bit about testing the cars. The thing is the press in general wouldn't have known. At the HK release, the whole testing process was extremely controlled. No-one drove the GTS327 without having a GMH staffer in the car, and they were not allowed to rev the engine over the red line on the tacho, which was fixed at 5500 for the 6cyl engines. A few weren't fooled including Rob Luck wasn't fooled enough to believe the scam, and he got hold of a private car to test. Read Racing Car News from September 1968, 0-100mph in 19.8s and 15.4s@92mph over the 1/4.
For HT-HQ 350 manual cars it was simply a matter of a minor fiddle with the Quadrajet to slow the cars down, and it appears the same was done for HJ 308 manual. The road testers of the HT-HG GTS350's wouldn't have known either, and the auto cars they got to test were fitted with power robbing accessories and tall diffs. Again Rob Luck in 9/69 RCN tested a GTS350 manual, this time a GMH supplied car but fiddled with. It is obvious from the times obtained of 0-100mph in 18.9s and 15.6s@92mph that the car wasn't in proper tune, there is no way a stock HT GTS350 is slower than a stock GTS327. You will not find a comparative road test done on one of these cars tuned to factory specs until the AMC article from a few years back. Again the tests done on new cars in 1969 were all done with a GMH staffer in the car.
It wasn't until HQ where the engines were identical and the diff ratios were identical for manual and auto 350 that the fiddling with the manual engine's carb came into light. Read Sports Car World from 7/72, the auto was 3 seconds quicker 0-100mph than the manual, and these weren't the only testers of the day to get similar results. They clocked 0-100mph in 19.8 seconds and 15.8s@87mph over the quarter for the auto. They even reported that they were puzzled, but the figures they obtained for the manual car were on par with the figures obtained by Wheels and Modern Motor on different GTS350 manual cars.
This is all historical fact, remember GM were not involved in racing and they had to be as quiet as possible with any furore over them building race cars. If need be you can even find good 1/4 mile data for properly tuned cars with no mods other than the exhaust being removed. Dave Bennett took his 9 day old GTS327 with 3.36:1 rear axle down the quarter at Calder. Its only mod was the exhaust was dropped and it did a 14.46 running the factory D70 tyres. There was a similar test done of one of the series production (PhaseII I think) Falcons done in 1970-1971, it was essentially a stock but properly tuned road car with free exhaust past the first join - this is where the 14.1sec time often claimed comes from.
The Ford figures are a total fact of reality, look here a 1975 Falcon 302 V8 and the F100 302 V8 ?
By your beloved Gross system I would not know bugger all that their was a difference in the engines at all, but the fact is their is a few differences and Net figures prove something is up ?
Now the XB sedan 302 has a 2 Barrel carter on it but the 302 F100 has a Stromberg on it and then as time goes on she gets a Carter 2 Barrel and then a 4 Barrel and all are quoted with their Net power ratings.
My mates old man had a 1977 F100 with the 302 V8 and it was gutless as, my old man had a 6 cyl 250 F100 and she was impressive for a 250, my dad said he test drove 3 F100 with 302 V8's and said they had no guts, so he bought the little 250 6 cyl, now I thought he was talking B/S at the time, but then we pulled the 302 of my mates F100 down and found this pissy little Stromberg and a intake manifold that had cone shaped holes where the carby bolts on to it, the bastard cones down to smaller than the Stromberg throttle body flaps to about the size of a 10c piece, no joke !
I know when talking about old chev engines that one has to talk in the old gross figures to get a handle on what is what, sort of. but as we se the chev engines we got in the Aussie GM-H cars do not always add up to what the Canada or USA cars truly had.
The Ford figures aren't when you look at what they quote for GT-HO vs GT. I don't love the old gross figures, they are simply the only figures you can use when comparing engines. Net figures are useless once you put different transmissions, exhausts etc into the equation. Figures even get quoted at different rpm for manual vs auto transmissions which is totally useless, just look at the net figures for the 1972 L48: 210hp@4400rpm, 300lbft@2800rpm for the manual and 175hp@4000rpm, 290lbft@2400rpm for the auto. They are the same 270hp gross engine, 270hp@4800rpm, 360lbft@3200rpm.
Aussie Chev (or Chev design in the case of the Canadian engines) are identical to what was in the respective US or Canadian vehicles depending upon whether the engine was Tonawanda or McKinnon sourced. They are the identical engines used in the USA other than for the distributors, and of course the sumps in HK-HG Holden. The GTS327 Tonawanda engine even uses the same distributor as the US 1968 L73 engine that it is. The revised distributor and initial timing will be because the fuel octane here was higher than what these engines were designed for in the USA other than for the HT-HG GTS350 manual engine, however the HK's distributor on these engines is essentially the same end settings as what the US engine got. Some of them got a different carby number to what was used in the USA (late HK with Canadian engine to 1972 HQ) as they got numbers specific to GMH however the carby tune was identical to the same engine in the USA, with the exception of 1973-1974 HQ 350 engines - these got the carby off the 1972 US L48 probably as after 1972 the US carbies were tuned for ULP.
Holden never had such a powerful up grade as a GT-HO P2 P3 such a engine V8 chev powered Holden's are only in the GT 4V 351 performance class, never in the GT-HO class.
The 1972 L48 HQ 350 manual is most likely for a twin exhaust and you will find the other is for the single exhaust. you are reading from the USA figures ?
Australia did not have higher octane than the USA in 1968 I am sure of that, now remembering that the USA octane rating is not the same as our RON as the USA use the MON rating.
The tune of the carby on the 1973-4 350 could be jetted some what like our ADR27A gutless rubbish was.
Remember the HX 5.0L manual does not have EGR ? so one has to wonder, it must of been the jetting as to why the loss of power, that has to be the only reason.
The last 327 was not like any other in the USA or Canada car powered engine I don't think.
The Last of the HG 350 was not the same as any USA or Canada Car powered engine I don't think.
The 350 HQ were the same as the USA car engine.
An unhobbled HT-HG GTS350 manual is not far behind a Phase II or Phase III in 1/4 mile times. Look at the respective mph too. The GT-HO's would beat it every time, but you'd have to be a good stick shift operator!
Those are USA figures I quoted. The ratings are at different rpm, not with different exhausts.
The 7042202 carby on our 1973-4 HQ engines was pretty much the same as the earlier ones, just a bit leaner idle I think.
No manual HX-VK 308/304 has EGR IIC. The loss in driveability for HX 308 is the inlet manifold and the loss of 4deg dizzy advance (I think HX went back to the HT-HQ 308 max advance). There could be some carby adjustments too, but don't think it was that bad. Remember once GMH got their act together the blue and black 308's went pretty well, the main difference being the manifold and they actually lost compression. The rest of the engine is pretty much the same and complied with the same emissions or higher.
Correct, the final versions of the HK and HG engines were specials, but only because neither was in production in the USA or Canada anymore - they were simply over-run and small quantity though. The original engines in both Series were the same as US engines (bar the distributor for the HT).
The early HQ 350 engines were the same as the US engines, but again the dizzy was different - these used the HK's distributor. Our 1972 engines were essentially the same as the 1971 engines, and the HQ 1973-4 engines were pretty much the US 1972 engine (used the 1972 carby and manual L48 dizzy).
No the HX intake does not restrict the stock 308 at all, you know why I know that for a fact is because I used one on a pre ADR heads 308 with it in stock form and with a 20/60 cam with stage 3 heads, I had some toe rag jet it lean and that was the biggest killer of performance that I came across, it was a gutless bag of s--t that used more fuel then ever before and after all the work I had done to make it perform, it had less power than the std engine I had before, so I know what is and what is not, I said listen c--- to this Dyno tune carby clinic low life, this is the jetting air fuel ratio that needs to be done to make it perform, No way would this clown do it, his reasoning was that I could not afford the fuel it would use ? now I had the car for 5 years or so and could get 22MPG on the highway but after this turd I got 16 to 16.5 MPG but the clown had destroyed my vacuum advance as well, in spite I would say because the problems started the day he ginned around with it.
That was the day that I never let any prick touch my car again without myself informing them what to do.
They f everything because they are morons that don't know jack mainly, sure they will tell you all the B/S under the sun to sell you shit you don't need.
I have had to argue with such morons even with brake pads, I said I don't give a toss about the cost I want the best, but no they wanted to use crappy cheap pads and I said no way in the world would I use grand mother brake pads, as I informed them I drove flat out over 200KM/H plus like nearly everyday.
They would just reject what I was saying to them, Just because I look like a Priest to them maybeAngel .
I drive 50,000KM a year so over time I have learnt what is and is not, than to have same piss ant try to piss in my ear.
Look the best performance is in the jetting and the exhaust tune without this, all you do is mainly worthless. get this and your away getting value for what you have done to the money spent on the engine.
Look the fact is a GT-HO P2 P3 has a 40/80 cam and that's a bloody big cam, all Holden chev engines had a shitty little std cam under 20/60 in reality and the fact is they do not make the power of a GT-HO P2 P3 at all and 1/4 mile times are shit, try 1000m that's where you will see the GT-HO P2 P3 kill any Monaro for dead, The first Windsor powered GT-HO is a worthy car that will even still eat any Monaro on the highway, and i don't say that because i am a Ford man, because i am not, i am a Holden man mainly, but not one eyed about it, I will bag Fords at the drop of a hat to if they deserve it as well.
The worst thing one can do on a road driven car is to go to big with your intake manifold and looking for the max power that an engine makes is not the bees knees at all, only a wood duck believes crap like that and sure the 40/80 cam in the HO's is a bastard to drive and sure the small cam in the chevs have their advantages on the 1/4 and on the track etc.
I spent many a nights out dragging other cars to know what was what and the HX intake was sure not a disadvantage at all.
castellan Offline
#45 Posted : Thursday, 11 February 2016 8:15:29 PM(UTC)
castellan
92061392 = VN to VS
92063314 = VT
Hope you are right, but a mate had a HJ 253 auto and i had a HG 253 auto both had 2.78 diff and my HG had it all over his, now his HJ had twin exhaust and my HG had a single 2 1/4 inch with a free flow muffler.
Hell i nearly had a 253 4sp HJ Monaro that had YT heads and twin exhaust with my stock bar exhaust HQ 202 3sp manual, he was a mate of mines sister, them YT heads with the big valves are no good on stock 253 as they loose performance.
Edited by user Friday, 12 February 2016 8:39:01 AM(UTC)  | Reason: Not specified
#46 Posted : Thursday, 11 February 2016 8:23:15 PM(UTC)
I have flow bench figures that compare the pollution 308 manifold to the HT to HJ one and it shows how bad the pollution one is. It is the only real difference between the engines. I'll dig out the Quadrajet tune for the two, not much difference in them from last time I looked. The pollution 308 wasn't anywhere near as sad as the 253 was though, from memory it was the smaller engines that copped a hammering by the motoring press, the press tests I have for 308 HX Sandmans is nowhere near as scathing on the engine as others are. HZ saw a manifold redesign and improvements.
castellan Offline
#47 Posted : Thursday, 11 February 2016 9:54:20 PM(UTC)
castellan
As far as I know the 308 HT-G-Q intake look the same as far as ports go but the HJ have a more squired off corners as does all the HJ 6 cyl as well and I remember someone saying that they are not as good as the pre HJ by a bit and then the HX came along and the ports are back to the old more rounded of type, not to mention the ribs in the HX ports at the carby and I am sure they will restrict flow more so.
I cant remember if the HZ was better than the HX I thought they were the same thing.
Blue motor V8's are nothing better from what I remember.
I have never driven a stock HX-Z or WB or VB-C-H-K-L that I thought boy this goes just as well as a Pre ARD27A 308 I thought they were all gutless beyond belief, I drove a QLD VH highway patrol with the single exhaust and it was as gutless as.ThumbDown what a bucket off, no brakes handling was total rubbish, I would not chase your grand mother in it.
The blue 3.3L went well compared to the reds and the EFI 3.3L had more grunt than the 3.0L Nissan engine, but when rev it right out the Nissan went well but down low it was a slug.
253 in the VH SS that a mate had from new was gutless as and another mate had a stock VB 253 that went better, I went to buy that 253 VH with the dude who had the VB 253 and he was canning it hard, I don't know maybe the secondary's were not hooked up ? but I said to the owner what's the go and he just went quiet, and this was back in 1986 or so.
Another had a WB 253 one tonne auto and I thought it was gutless as well.
A best mate had a 1980 WB Statesman Caprice bloody nice car but gutless as and that was about 1987.
castellan Offline
#48 Posted : Thursday, 11 February 2016 10:34:53 PM(UTC)
castellan
Originally Posted by: gm5735 Go to Quoted Post
You beat me to it.
The RON was 87 for standard in Australia from what I remember and super was 98.
I don't know about before that but I do believe it was maybe just the standard fuel that increased of different grades as the years went on, maybe from the compression of Holden it tells a story as they start from 6.5:1 with the first and then she bumps up to 6.8:1 in 1956 and then 7:1 in 1958 then to 7.25:1 in 1960.
Not to mention the rubbish before the 1950 Shhh that could run on hair spray and crude oil Eh?
I asked my Dad once about the fuel in the old days as he owed fuel stations but he could not remember what it was. I look for it on the web but found nothing but different company's had different fuel and they spun some line in the day about their fuel being better that the other.
My dad had a Ford Customline in the 50's and he ran standard at home but said when he came down to the coast he had to run the better super fuel or she would ping in them days.
One dude I was talking with of late said that the fuel we get nowadays is not as good as what it was in the days before, B/S it is the fact is it's better than it has ever been.
Leaded fuel was crap caking up your engine, I pulled the heads of a mates 308 that had done maybe a months driving and it looked by the carbon build up that it had did 100,000KM and I remember a dude that was going off about REPCO recon engine that bugged up after about 4 months, he was sure as eggs that they sold him an old engine, because of the carbon build up he seen it had, he was jumping up and down mad as hell about it.Laugh
#49 Posted : Friday, 12 February 2016 6:23:39 AM(UTC)
HT-HJ are the same exact manifold. Only changes are HT-HG have an extra heater hose hole at the front and HJ (actually introduced with LH) has an extra drilled and tapped hole for the carby return spring bracket. 1974 HJ even use the identical carby to 9/73 onwards HQ, and that same manifold and carby continues on export Holden until the end of red motors (I have one here from 1978).
They pretty much are gutless compared to earlier 308's, but see if you can drive a 308 manual VH-VK, these go pretty well and the main improvement is a decent manifold.
#50 Posted : Friday, 12 February 2016 7:25:44 AM(UTC)
I think you must have driven a lot of Holden V8s where the Q-Jet's secondary simply didn't open.
I've tuned & driven 100s of these things & while they didn't go quite as well as a good HJ 308 or Brock Commodore, many Blue V8s (both 4.2 & 5.0) were very stout performers.
One of my own cars, a WB Series 1 DeVille goes very well & often surprises people. It didn't when I first purchased it, but does now, hence my comment re: the Q-Jet's secondaries. I well remember tuning HK/T/G/Q/J V8s (both SBC & Holden 308) where at least 80% of the cars we got into the shop had issues with the secondaries either not opening fully or not at all. I'm not singling out Holden here either, Many Falcon GTs (Autolite carby) & XC/D/Es (with Carter Thermoquads) were also bad in this area.
Another point often missed is rear axle ratio. Cars with taller diffs don't accelerate as well as those with lower diff ratios (for obvious reasons), but the gearing doesn't have the change radically to achieve improved performance. A good case in point is the VK EFI 6 Commodore. These were available in auto only & early cars got a 3.08 diff. These cars went well for a Holden 6 but were't 'startling' performers. Mid-way thru the VK series, GMH introduced the BW diff & changed the EFI's final drive ratio to 3.23. Now 3.08 to 3.23 doesn't sound like a radical change, but side by side these 2 cars were chalk & cheese. The 3.23 cars could easily spin the rear wheels in the dry & were great off the lights.
Edited by user Friday, 12 February 2016 7:40:19 AM(UTC)  | Reason: Spelling
#51 Posted : Friday, 12 February 2016 7:51:42 AM(UTC)
^^This is how GMH hobbled the manual HT-HQ 350 press test cars. It isn't hard to make the secondaries not open properly, and an easy fix to rectify it. The amount of Quadrajets that were removed for Holleys in the 70's and 80's was amazing, but all the car needed was a carby tune and adjust.
#52 Posted : Friday, 12 February 2016 8:11:14 AM(UTC)
The lowering the performance of the GTS327/350 would have more to do with public opinion that the suppose ban on motor sport by GM. It just does not make sense that Holden, all the way on the other side of the world, had to hide the fact they were making a "performance car" when right under their noses Pontiac was making a GTO. Just like Pontiac, Holden never went racing themselves.
The HK Press release had a list of possible questions and answers and in there it was about why Holden would make such a powerful car. This was all new territory for Holden, they were building cars for the masses, and now they were building this car. Although the 186S HR was quite quick, it was never really advertised or marketed as a high performance option, just a performance option.
I believe Holden did not want to bring on, what eventually happened in 1972.
Warren
#53 Posted : Friday, 12 February 2016 8:28:55 AM(UTC)
Probably correct Warren, but for the HK they did have to tread carefully as they did not want the wrong sort of attention from the public (via the press) and consequently from GM corporate as a result. The HK engine was detuned (via the secondaries) to the point where it was on par performance wise with the Falcon GT, which they had on hand when they did the press drive day at Lang Lang on July 16 1968. GMH did not want to start a performance war. Still the GTS327 attracted the interest of Politicians and was in fact the trigger for blanket speed limits in NSW as it was the car used by the NSW Transport Minister to assess the situation.
#54 Posted : Friday, 12 February 2016 9:16:04 AM(UTC)
Wasn't the HK Monaro/Brougham press release, drive day held at Surfers Paradise Raceway ?
castellan Offline
#55 Posted : Friday, 12 February 2016 9:22:29 AM(UTC)
castellan
One bloke I know who bought a XC 5.8L GXL Falcon from new said that the secondary was not working until the 10,000km service they found out.
Mainly you can hear if they are opening, cant say I remember that VH SS 253 open so that maybe why, some idiots did block the secondary off because they claim to save fuelLaugh
I know what gearing does and I had tried ratios in my auto 253 HG from 3.55 and 3.36 and it came with 2.78 and I found 2.78 to be the best performing ratio the 3.36 and 3.55 were crap but I would think 3.08 would of been best but they were rare as in the day.
My mate still has a red manual VC Brock commodore and he is thinking of selling it last week as he never drives it much at all nowadays, it's like new and he has had it from 1986 I think but it has never perform well at all really, it would not beat a stock 308 HQ with twin exhaust I sure of that.
He has done the engine up 2 times now and he says the bastard never has gone harder than his worked 202 G Pack Torana but that thing killed every XU-1 we dragged with it and it had twin Stromberg's on it.
A mates mums stock as a rock 3.3L auto VB could do 185KM/H she was slower on take off, It must of had 3.08 diff in it or maybe a 2.78, but most would only do 165KM/H with a std 3.36 ratio.
A WB 3.3L auto ute could do 185KM/H as well as does the VC 3.3L.
3.3L EFI could do 200KM/H
castellan Offline
#56 Posted : Friday, 12 February 2016 9:30:36 AM(UTC)
castellan
No the intake is different on all HJ in the runners they are more sharper in the edges be it 6 cyl or V8.
I have talked about this once on a forum about the casting intakes and we were wondering why it was so that Holden did such a thing.
Remember I am only on about the runners shape and nothing other than that difference.
#57 Posted : Friday, 12 February 2016 9:43:20 AM(UTC)
No.
Monday July 15 was the dealer releases around the country (this is what my Warwick Yellow GTS327 was used for).
Tuesday July 16 was a brief introduction for selected journalists at Lang Lang, the sole (red) GTS327 present you can see on the cover of September Modern Motor - the shot is at Lang Lang. The press lead times for their September issues was the reason for this event.
Sunday July 21 was the press conference at Surfers Paradise Chevron.
Monday July 22 was the Driving Evaluation at Surfers paradise Raceway.
#58 Posted : Friday, 12 February 2016 9:44:58 AM(UTC)
I'll look at some tonight, I have examples of all of them in the shed. It may well that the casting patterns were renewed at HJ hence why they are sharper.
castellan Offline
#59 Posted : Friday, 12 February 2016 9:47:12 AM(UTC)
castellan
You are spot on their.
Many Mechanic in the day were a dill when it comes to tuning a car well and when talking to them they have come back with crap like the hand book says X and they must be right because they have worked out what is best, B/S ! simple minded idiots that can't think for themselves nor do they care less, such are A grade amateurs.
#60 Posted : Friday, 12 February 2016 1:33:46 PM(UTC)
I do not think it would be GM corp that would have kicked up stink about Holden manufacturing a high performance version of the GTS, (after all by 1968 GM divisions were making some pretty awesome muscle cars in the US) more the public as to why Holden was making something so fast.
The more I think about the reason for the world wide ban on motor sport for GM divisions, the production of GM Muscle cars in the mid to late 60s, the whole hide the fact we are making a muscle car here makes no sense. As I have pointed out before, the GTS 327 gets a separate model number, not just an option like the SLR5000, GTRXU1. People say this is to hide the fact, but the same was applied to the Brabham Torana, so were they must have also hiding that from GM due to its possible high performance repercussions. As it has its own model number then it is clear as day that you are making a high performance model, as it comes up in the model list. The GTRXU1 and SLR5000 do not come up in any model list. If you were given all the model information on the first HB Torana a novice would need to do a bit of reading to find there was a Brabham high performance option, when it becomes a separate model it is right there on page 1. So making a separate model does everything but hide it.
The "American Muscle Car" thing here had only started the year before with the XR GT. Before that it was all British thinking, small nimble car with a little more poke. In 1967, pre XR GT, a V8 was simply a luxury item, or for those towing. There was a small US Muscle thing starting and some dealers were importing GTOs etc.
Then Ford goes and makes the GT and hammers Bathurst. Up until then its all British, Cortina, Mini etc. My theory/opinion is a Ford US heavy came out here, saw what they were doing with the Cortina GT and said, hey you need to build a V8 "Muscle car" version like we do in the good old US of A.
Had Holden hit back with a car that was way superior in 1968 it may have been a case of too much too soon. They knew the Ford "Official figures" and they probably said "lets make ours about the same". (you only need to win by a car length)
Mind you Ford may have been doing the same with their cars, especially after that idiot took a photo of the speedo at 140MPH, bring on the supercar scare.
Warren
Edited by user Friday, 12 February 2016 1:35:48 PM(UTC)  | Reason: Not specified
Guest (11)
9 Pages<12345>»
This page was generated in 0.280 seconds.
