9 Pages«<6789>
castellan Offline
#141 Posted : Wednesday, 24 February 2016 9:55:02 AM(UTC)
castellan
Again Gross is the only way you can compare engines, once they are "as installed" the comparison is no longer valid as the power output can be affected by things as diverse as:
HD radiator.
Viscous or fixed fan.
HD clutch.
Body style (exhaust bends).
Air pressure.
Temperature.
etc etc.
You even see DIN figures quoted at different rpm as the engines cannot reach the peak power rpm as installed due to restrictive exhaust, manifold or even an auto transmission.
Gross figures are the engine on a dyno in controlled conditions. The peak power and torque are quoted straight off the dyno graphs unless they are deliberately hidden (which can happen with any power figures). Manufacturers can be sneaky and not even tell lies to hide power figures, they just quote them at different rpm, or not change the power figures for obviously modified engines compared to the previous engine eg GT-HO or L34.
Rubbish HD radiator makes no difference at all.
HD clutch BS as well.
Air pressure and temp etc is controlled in both DIN and more so in ECE.
The fan makes bugger all difference the exhaust bends are all good as DIN picks up any loose and the person is now informed that something is different.
It's all about being informed as to what is truly what with DIN figures they maybe the same engine exactly but they don't perform the same and that's what people would want to know.
Your argument is like a simple wage earners position and votes ALP as he does not give a toss about reality or the facts and as such just puts what they want to hear up front.
If I were to run a business like that I would not know what the hell is truly going on.
I want to know truly what the hell is truly what at all times so I am truly in control of every thing in reality.
That's the difference between leadership and just following along with the flow.
Look at the XA-B gross figures for the 302 240HP they say !!! and a 308 is 240HP as well in Gross HP, so ok then should one believe that this is truly a fact, to you it is ? but hang about the 308 has a 4 barrel carby and the 302 has only a 2 barrel on it, something is up ? I have drags a lot of XA-B 302 V8's and driven them and they sure did not perform like a 308 did.
Now in the pub a dude will inform me that his 302 is just as powerful as my 308 because the Gross figures say so.
A XB 302 Net HP is 159HP at 4400RPM and 251LB at 2500RPM this is reality or a 2 barrel carby that they only have.
A XC 302 Net HP is 202HP at 4600RPM and 268LB at 3000RPM but this has a 4 barrel on it.
So just by this 2 barrel vs 4 barrel carby point we can see that we have a loss of at least 40HP regardless and it just goes to prove Gross is just rubbish.
It's like some fool that knows my business turns over 4 million a year, so that clown thinks I am filthy rich and doing so well, but in fact the reality is, it could be a shockingly bad performance.
#142 Posted : Wednesday, 24 February 2016 10:16:32 AM(UTC)
Rubbish. HD radiator means a different fan. HD clutch means more rotating mass. A bigger alternator to drive more electric loads means more drag on the engine. Auto torque converter changes everything.
DIN is useless for comparing engines especially for their evolution. How many times do I need to say it!! You cannot quote the same figures for an XT5 5.0L in a VC and a WB - different exhaust manifolds, different air cleaners, different exhausts, different pulley system. The Gross power of the engine isn't encumbered by any of this, so if you are going to show engines side by side the figures have to be independent of the vehicle they go in otherwise it is a huge waste of time and effort and means absolutely nothing. IF you are lucky enough to have one particular engine that you have BOTH data for you can do some comparisons either side of that engine, but unfortunately I don't think I'm going to find SAE Gross or SAE Net figures for the VB Commodore 5.0L engine. I have the Gross figures for the VB 4.2L engine and the DIN figures as well so at least there is this to work with. Fingers crossed I will find the Gross figures for the 9.4:1 HZ/VB 5.0L and then I can work with it.
I actually just got GMH SAE net engine dyno figures for the VH Group3 high output 5.0L engine (not the optional VH Group3 5.0L but the special high output engine) but I don't have DIN figures for it to use for comparison either. It is just under 315hp SAE net at 5500rpm.
castellan Offline
#143 Posted : Thursday, 25 February 2016 12:33:21 PM(UTC)
castellan
The fan and the weight of the HD clutch as go bugger all to do with it.
7 blade fan on my HG 253 Premier with air con ? would be bugger all to a 4 blade or a HD 1 tonne clutch behind a 202 and with Gross HP no one would know or care and with net it would be nothing to bugger all.
The VC and WB DIN power figures are all the same, the only difference is the Statesman comes std with twin exhaust.
No one cares what a engine power is in Gross HP because it does not represent what power it makes in the car, it's totally useless.
The 5.0L VB commodore engine is just the same engine as the HZ it has a claimed 216HP Gross.
The VH and VK SS Group 3 has 184KW at 4700 and 418 NM at 3500 That = 247HP
The VK SS GROUP A has 196KW to 200KW at 5200 and 418NM at 3600 That = 263HP or 268HP DIN in my books but maybe 315HP in Gross HP.
I don't know why the discrepancy over the 196 KW but the two people I know who bought this blue VK from new had a big single exhaust on it and the engine was red and had a nice sounding cam at idle.
Brock did make a 5.6L Holden engine in the VL Calais Director with 310HP Gross at 4400 and 396LB at 3200 .
#144 Posted : Thursday, 25 February 2016 2:34:55 PM(UTC)
Gross is the go, don't care what anyone says!
Yes the VB 5.0L is the same as the HZ, but not the same as the 9.7:1 HZ engine and there are no figures as yet for the 9.4:1 HZ engine. That is the problem.
None of those engines you have mentioned are the one i'm talking about. VH Group3 is a 4.2L engine. There were three optional engines on the Group3:
The V5H HDT improved 308 engine: 9.2:1, 180kW@4750rpm, 430Nm@3500rpm.
The 5.6L engine, don't have proper figures for this.
And there was a high output 308, with hand finished heads and combustion chambers, L34 pistons and rods for 10:1 compression, blueprinted and balanced bottom end, Group C bearings, big cam and matching springs, anti-bleed lifters, SG Iron top rings, decked block (zero deck height), cold air ram intake, baffled sump, low restriction tailpipe etc. Each owner that optioned this got a dyno printout - HDT used GMH's dyno engine using the GM20 test (SAE NET). The one that came with this car was 314.7hp @ 5500rpm, 333.1ftlb @ 3500rpm.
castellan Offline
#145 Posted : Thursday, 25 February 2016 3:25:36 PM(UTC)
castellan
I have the info for the VH Group 1 2 and 3 some where.
I have never heard of the 308 you are on about in the VH.
#146 Posted : Thursday, 25 February 2016 3:44:08 PM(UTC)
Don't take much notice on the text on this page, although i'm interested in finding more info on the 5.8L engine mentioned. Just scroll to the HDT sheet at the bottom.
http://www.uniquecarsand...nical_specifications.php
castellan Offline
#147 Posted : Thursday, 25 February 2016 3:47:31 PM(UTC)
castellan
The 308 in the VB had only 315 to 320HP when Brock HDT raced in 1980 with the small valve heads.
castellan Offline
#148 Posted : Friday, 26 February 2016 12:51:46 PM(UTC)
castellan
Unique are not spot on in many of their print.
The VH Group one was a stock 253 engine 100KW
The VH Group 2 was a 253 with Group 3 air cleaner and twin exhaust 115KW
The VH Group 3 HDT 001 the first was a 253 with as you say mods, 153KW and may of been the only one.
The VH Group 3 5.0L 184KW
And a engine mod called HO with 235KW now this engine may of not came as a new car, but afterwards Brock HDT improved, Their is one with a alloy tag with a spread sheet saying number 1174 284 and so on and not to rev it past 6000RPM.
And there is a 5.8L with 251KW that is the same deal as far as I can make out they did not come sold as new with such engines.
castellan Offline
#149 Posted : Friday, 26 February 2016 1:13:48 PM(UTC)
castellan
I do not believe that the 5.0L from HX had 9.7:1 as only the HJ got 9.7:1
So the Gross HP of the HX-Z is 216HP 161KW as it's stated.
My original HX Owner manual publication May 1976 says 9.7:1 so maybe the next publication says 9.4:1 so it may all have to do with a print mistake, as the engine was not announced as yet in May.
So we may just find this is a fact in the next publication owner book.
#150 Posted : Friday, 26 February 2016 3:28:52 PM(UTC)
I agree hence why I said to ignore it all, just read the HDT sheet at the bottom. That is what a high output engine is.
Most HDT VH's were HDT modified engines and didn't leave GMH that way - this didn't happen until later where GMH built the HDT mods into the engines.
#151 Posted : Friday, 26 February 2016 3:31:21 PM(UTC)
HX and HZ are 9.7:1. The only V8 rotating assembly change at HX release was the compression ratio on the 4.2L changed from 9.0:1 to 9.4:1. HZ then changed to 9.4:1 at VB release.
castellan Offline
#152 Posted : Friday, 26 February 2016 9:52:42 PM(UTC)
castellan
Looks like you could get a 5.0L Group 2 as well, it's just the stock engine.
And From Group 1 you could order a whole lot of options, so it just looks like the whole thing is just so many options.
So as for the engine Group 1 is a 4.2L stock standard or optional bigger air cleaner.
Group 2 is a 4.2L with bigger air cleaner and chrome, headers, some mods to heads small valves still ? intake manifold mods and optional 5.0L V8 stock standard engine with chrome and maybe headers.
Lets talk the Brock VC it just had big air cleaner big valves and headers and that's it 160KW DIN at 4500, standard cam ?
Then we have the VH cop BT1 with 145KW at 4400
V7X has 170KW, it must have the same cam as V5H but standard valve heads.
Then the V5H 177KW at 4800, now this has to have a bigger cam ?
And the VK A9L must have a bigger cam than all as well as larger diameter lifters in this block.
What can we say about this lot.
#153 Posted : Saturday, 27 February 2016 6:45:55 AM(UTC)
It is why i'm trying to find all the correct data, however I think a lot of HDT stuff is not the same as others.
castellan Offline
#154 Posted : Sunday, 28 February 2016 11:00:12 AM(UTC)
castellan
I am looking into why the VC blue motor 5.0L with standard single exhaust has more power over the VB red motor.
Red has 107KW at 4000RPM / 321NM at 2200RPM.
Blue has 117KW at 4000RPM / 336NM at 2400RPM.
Does the VC V8 have a bigger or better flowing exhaust or is the cam spec a bit different or is it just the CDI dizzy and the position of the spark plug change that does all this.
The twin exhaust does not make any more HP power.
Red 126KW at 4250RPM / 336NM at 2500RPM.
Blue 126KW at 4400RPM / 361NM at 2800RPM.
This is the great thing about DIN power figures and it makes me think why the Blue did not make more than 126KW we have no graph to look at, but a increase of 25NM is not bad and that it's at 300RPM more is interesting.
#155 Posted : Sunday, 28 February 2016 12:33:59 PM(UTC)
Original GMH documentation for the VB 5.0 is (DIN):
114kW@4000rpm 344Nm2200rpm single.
125kW@4200rpm 352Nm@2600rpm dual.
XT5 5.0L:
117kW@4000rpm 336Nm2400rpm single.
126kW@4400rpm 361Nm@2800rpm dual.
These figures are straight from the VB Service manual and the Service Manual supplement for the XT5 improved performance engines.
There isn't much between them, it doesn't look like the red engine revs out quite as well as the blue engine which could be the manifold on the red engine, or it could be the aircleaner on them both beginning to restrict performance or it could just be the slightly better spark on the blue engine allowing slightly more revs before the power curve dips.
castellan Offline
#156 Posted : Sunday, 28 February 2016 3:22:13 PM(UTC)
castellan
XT5 5.0L:
I got my figures from 60y of holden book.
The VB single exhaust is interesting on your figures 244NM can't be correct ?
#157 Posted : Sunday, 28 February 2016 3:48:36 PM(UTC)
It is 344Nm not 244Nm. Service manuals appear to reflect the Features Manuals and Engineering Technical data for all other Series, so i'd trust it. You'd have to ask Dr Terry where he got the figures from. The VB Service manual is dated 1/79.
You've also displayed why DIN figures are a pain in the proverbial when comparing engines, as you don't know if it is internal or external influences on power and torque variations. A gross figure would show you which engine has the most potential given optimised externals.
Edited by user Sunday, 28 February 2016 4:32:29 PM(UTC)  | Reason: Not specified
castellan Offline
#158 Posted : Monday, 29 February 2016 12:23:59 PM(UTC)
castellan
I just made a mistake with the 2 I meant 344NM.
DIN figures are spot on and Gross are total rubbish, this point has only got to do with an mistake and that can happen regardless.
No one uses Gross power figures nowadays, Australia started DIN from 1978 USA from 1972 and Germany must of been before all of them to work out a realistic figures that come down to reality and no one has gone back to the backward Gross SAE figures have they.
If you were to talk to a person born from say the 1980's on they would think Gross SAE came out on the Ark or maybe with Charlemagne.
#159 Posted : Monday, 29 February 2016 1:27:10 PM(UTC)
As before, nope. The variation in DIN figures between Commodore series has too many extra external (to the engine) variables to make a meaningful comparison between the engines. As you found it makes you start to wonder what else is going on to affect peak power and torque that is not internal to the engine assembly. Items such as aircleaner and exhaust have a massive effect on the situation. Gross allows you to compare them directly - the figures quoted in Gross are not rubbish, they are a true peak figure read straight off the engine dyno curves when a GM1 test is applied. Such a test has no or minimal external influence on the engine to worry about. It is as simple as that and will always remain as simple as that!
castellan Offline
#160 Posted : Monday, 29 February 2016 6:06:20 PM(UTC)
castellan
Well stating that a 308 has 240HP Gross means nothing at all in reality.
Because it's just not true.
I could have the option number L31 and year of it, to inform me of that if I wanted to know what it was, but if I wanted to know what does my HQ 308 make with the standard single exhaust and what does it make with the twin exhaust ?
Now I want answers ?
You know that the new 4.0L Falcon engine has power rated in 91 octane and the 95 octane and also 98 octane ?
So one does have understanding that this engine will perform better on the higher octane.
Now not all engines will perform better if you go higher octane.
Now what would be know if it was in Gross figures, nothing at all.
I wonder what the Gross HP is of the new 4.0L Falcon is. 281HP Net it is if it's 210KW DIN on 98 octane but Net would be maybe 300HP.
Might be putting that one in the old HG Monaro ay or maybe the turbo 4.0L ay.
Guest (7)
9 Pages«<6789>
This page was generated in 0.133 seconds.
