I have a hot rod project that uses a HT Holden subframe but my suspensions arms are not suitable for reuse. Can the HG suspension arms be used on the HT subframe. http://i109.photobucket....mouthChassiswithHTHo.jpgEdited by user Sunday, 1 June 2008 10:21:01 AM(UTC)
| Reason: Not specified
hi mate yer mate they will fit all those modles hk ht hg are all exacterly the same exept for the grills and the tail lites everything else is the same it all fits on only diffrance is what colour it is say a blue car well that will have blue seats ect ev
Id like to believe you but then again you are an Anonymous Poster.
I'd like to believe you but then again you are an Anonymous Poster.
Thanks: 1 times Was thanked: 615 time(s) in 582 post(s)
Fom July 1969 HT and HG front ends are the same. The first month or so of HT had the same upper control arm mounting locations as the HK, but they were raised in July. The wishbones are the same though. Just make sure you have HT/HG ones though as HK won' |
Fom July 1969 HT and HG front ends are the same. The first month or so of HT had the same upper control arm mounting locations as the HK, but they were raised in July. The wishbones are the same though. Just make sure you have HT/HG ones though as HK wont |
